engine fan not going off??
Does anyone know which relay it is?
i have two options - “engine cooling fan” or “cooling system fan”.
both different sizes, a 12v 30a and a 12v 70a.
The most common cause of a cooling fan coming on fuel speed as soon as the ignition is switched on is because of a failed coolant temp sensor. If the pcm doesn’t know what the coolant temp is it will put the fan on to prevent an overheating condition. There is often more than one coolant sensor, one for the fahs and one for the pcm.
if you give me the cars details I can look up a wiring diagram and see how the fan system works on your car. I would need to know the make/model/year/engine code or reg number to find the correct diagram.
Have you got the problem that the cooling fan is not switching off ?
