Door ajar light on car wont lock
Hello all
Thankyou for letting me join
Can you help i have a ford fusion 2 ive had to take my central locking fuse out yo lock my car the interior lights stay on so have turned them to off i turn engine off and head light on alarm goes off with doors all shut. I have mot soon and hope you nice people could help me
Kind regards
Hello and welcome Stephen
Your question would be more likely answered In the Fusion section Here: http://www.fordownersclub.com/forums/forum/26-ford-fusion-club/
Welcome Stephen! :D
+1 Joss, You are likely to get more answers in the Fusion section :)
Hello & welcome :smile:
Hi Welcome
The door ajar signal will prevent full locking, and may set the alarm off, if it is not working.
First step is to find out which door. Most Fords have a battery saver circuit, that turns the interior lights off after half an hour or so, even with a door open, or with the light switch on. Turn the light back to auto, leave it on, and see if it turns off. Then open a door, and if that puts the lamp on, it is not the faulty one. Repeat for each door.
On the Focus, there is a quicker way:
Press and hold in the rear demister button while starting the car and you will get a tone.
Once activated the test mode will sound a tone when any switch or lever is triggered.
Open each door in turn, bonnet, boot, wiper, indicators etc and a tone will sound/hazard lights will flash which will make it easier to pin down any faults.
May not work on the Fusion, but worth a try.
The door ajar switches are built in to the door latches. Once the faulty one is identified, removing the door trim panel will reveal the wiring & latch, for further tests.
Hi peter
I followed your steps with the light. Its the driver door the light does not come on. All the other doors and tailgate all turn the light on.
I am pleased that worked!
Unfortunately, when it comes to fixing it, I am of less help. I know how to remove door trims on a Focus, it is pretty easy, but there are a few little tricks to release the hidden clips. Haynes is where I found it all. If you have some basic tools & a smidgen (or more!) of diy / technical knowhow, Haynes would be a good investment. They are rather laughed at by some (inc. me at times!), there is a lot missing, and some wrong stuff in them, but they are still an invaluable goldmine of info.
Otherwise you are at the mercy of a local garage. But at least you can point them in the right direction: Door ajar switch on driver's door.
