Guest Posted May 26, 2017 Share Posted May 26, 2017 I'm sorry if this topic has already been made but couldn't find anything in the search. I need to pull the fuse for my SYNC as the gremlins have decided to wake up and not allow me to play my music from my phone through bluetooth anymore. Tried master reset of SYNC and also resetting my phone, still no luck. One problem, I have no idea what fuse to pull, can anyone help please. Cheers. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted May 26, 2017 Share Posted May 26, 2017 It's in the manual. If you don't have one there are digital ones on the Ford website. 2 Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted May 26, 2017 Share Posted May 26, 2017 Saved you the hassle. Try fuse 24, it should be 10 amps (diagram underneath). That controls both the bluetooth and Sync. Failing that try 21, which is the stereo. 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted May 27, 2017 Share Posted May 27, 2017 Saved you the hassle. Try fuse 24, it should be 10 amps (diagram underneath). That controls both the bluetooth and Sync. Failing that try 21, which is the stereo. Legend! Pulled no' 24, popped it back in and music connection is working perfectly now.Thanks pal. Quote Link to comment Share on other sites More sharing options...
Ishuwish Posted May 11, 2018 Share Posted May 11, 2018 Is this the same for fiesta 2014 eco Boosts? My bluetooth keeps Showing error and then connects a while late. Also when I reset bluetooth, it just doesn't appear On my mobile to then conenct. My car didn't come with a manual (second hand). Can anyone help in a diagram for this ones fuse box, and also how to master reset bluetooth in the car. Much appreciated. Ish Quote Link to comment Share on other sites More sharing options...
ThaiFiesta Posted May 11, 2018 Share Posted May 11, 2018 You should start with resetting bluetooth through the onscreen menu. Failung that then try pulling fuse 12 under the glovebox. Failing that then physically unplug the Sync module, also under the glovebox usually attached to the kickstart or otherwise affixed to the loom. Quote Link to comment Share on other sites More sharing options...
Stekop Posted October 10, 2019 Share Posted October 10, 2019 Hi my Fiesta zetec s 2009 has the same problem says delete a phone off the bluetooth to many are paired but when I go and delete one there are none there. Help me please as I’ve try looking at the fuse box under my glove box but some of the fuse are not there. And don’t want to pull the wrong fuse Quote Link to comment Share on other sites More sharing options...
