fiesta zetec Posted August 7, 2010 Share Posted August 7, 2010 Hello everyone,has anyone with the latest fiesta had the problem that the horn goes off when turning the steering wheel in both directions. This is embarrassing when driving to and from work daily? Quote Link to comment Share on other sites More sharing options...
artscot79 Posted August 9, 2010 Share Posted August 9, 2010 Hello everyone,has anyone with the latest fiesta had the problem that the horn goes off when turning the steering wheel in both directions. This is embarrassing when driving to and from work daily? strange sounds like a loose wire try at the horn under the bonnet usually the pass side at the front under the car check the wires and make sure thay are clean after that you would need to get a wiring diagram and find the wires linking to the horn you could remove the horn on the steering wheel and check the contacts there Quote Link to comment Share on other sites More sharing options...
