Help - Need Clarification
5 replies to this topic
#1 Zordie
Zordie
    Newbie
  • Pip
  • 3 posts
  • Name: Michael
  • Ford Model: Focus
  • Year: 2003
Posted 05 March 2013 - 05:52 PM
Hi all
I am currently having an issue with my l'il Ford, It is a 1.8 TDCI saloon, and the problem I have is as follows:
Intermittently, when I put pressure on the accellerator, the revs go up but the speed does not (or very slowly) until I release the pressure.  It usually does this in 4th or 5th gear.
Usually once it starts doing this it will continue to do so often until I leave it for a while (I.E drive it the next day)
It is most likely clutch but it always bites ok, even on hill starts, which makes me wonder whether it is.
Any suggestions?
Thanks in advance
Mike
#2 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 05 March 2013 - 05:56 PM
from what you say, that does sound like the clutch slipping
#3 Zordie
Zordie
    Newbie
  • Pip
  • 3 posts
  • Name: Michael
  • Ford Model: Focus
  • Year: 2003
Posted 05 March 2013 - 06:01 PM
Darn it... Thanks.
Expensive times :(
#4 Zordie
Zordie
    Newbie
  • Pip
  • 3 posts
  • Name: Michael
  • Ford Model: Focus
  • Year: 2003
Posted 05 March 2013 - 06:23 PM
How much is a clutch change on a focus typically does anyone know?
#5 jeebowhite
jeebowhite
  • 4,290 posts
  • Name: James
  • Ford Model: Focus CMAX 1.6 CVT TDCI
  • Year: 2005
Posted 06 March 2013 - 05:59 AM
If you shop around, you could get it for around £300?
#6 Andy H Dibley
Andy H Dibley
  • 271 posts
  • Name: Andy
  • Ford Model: Focus
Posted 06 March 2013 - 07:23 AM
Depending of whether they also think its worth changing the Dual Mass Flywheel as well at the same time.
Do hill starts you're less likely to notice to the slip, as you are manual slipping the clutch yourself. Clutch slip really comes noticeable with it fully engaged and you stomping on the accelerator, or increasing the load on the engine eg, cruising on a flat bit of road in fifth, hitting an incline and keeping it in fifth.
