Does anyone know much about the wastegate mechanism inside turbo for mondeo 2.0 TDCi 130? Ive bought a mondeo with turbo issues, the guy I bought it from had changed the actual turbo but kept the old (faulty) electronic boost actuator. After digging around a bit, I found out about the connection problems inside and got about soldering them up. Got that part working but the turbo was so clogged up with soot that the actuator was stuck. So ive dismantled the turbo, leaving the cartridge part entact, fully stripped down the wastegate mechanism, cleaned it and am now in the process of rebuilding, is there anything to be carefull of when doing this? Ive got all relevant locating pins, spacersand rollers, just wwondering if anyone has done this with feedback good or bad to give? Thanks
Seems like you know what you are doing
