Russhux
2010 Sidelights
2 posts in this topic
HI i have a ford S-max 2010 titanium X!
I would like to change the side light bulbs.
But how is the question ? Do i need to remove the main head lights?
not sure as I havent changed the SMAX specifically, but almost all Fords (my Focus, CMAX and the Mondeo [which the SMAX is based on]) require you to remove a couple of Torx T 20 / T 25 screws, then you need to remove the light assembly. When you have pulled the assembly out, you then need to click the back cover off, then just pull the sidelight bulb out with a gentle tug and replace
