slatez90 Posted August 4, 2014 Share Posted August 4, 2014 I was driving just about to turn right into a station when my car lost power and wouldn't move. My friend had to get out and push me into the station. I tried a few times turning the key but just wouldn't turn over. A mechanic came out to me to recover the car back to my house and had a quick look over and said it was the cam belt. I got to the cam belt and seemed like there was no damage, the belt was in good condition and the pulleys seemed ok. Any ideas? Quote Link to comment Share on other sites More sharing options...
stef123 Posted August 4, 2014 Share Posted August 4, 2014 Did you manage to inspect the full belt? If the belt is still intact and under tension it may be that it has lost some teeth. If you can, get a spanner on the crank pulley bolt and see if the engine will turn by hand Quote Link to comment Share on other sites More sharing options...
slatez90 Posted August 4, 2014 Author Share Posted August 4, 2014 I will try that when I get home. I did notice a couple of the teeth were missing. If it turns by hand what does that means if it doesn't turn by hand what does that mean. Thanks Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted August 4, 2014 Share Posted August 4, 2014 It means that you had better stick your kidney on eBay.... If its lost teeth off the belt, then as its gone round the timing would have gone. It means your probably looking at damaged valves at best, damaged piston, and metal filings in the combustion chamber at worst... Quote Link to comment Share on other sites More sharing options...
stef123 Posted August 4, 2014 Share Posted August 4, 2014 As above, if it's missing teeth then the timing will have slipped. Your looking at a minimum of bent calves, how many and he extent of the damage will only be clear once the head is removed. Quote Link to comment Share on other sites More sharing options...
