sarahlouise40 Posted August 25, 2014 Share Posted August 25, 2014 Hi, i wonder if anyone can help me, I've got a 1.3 ford fiesta 2002, recently it has been starting to judder when driving along, pulling away isn't a problem and it pulls away smoothly but when changing up to 2nd/3rd gear after i let me foot off the clutch the juddering starts to appear, it feels like your going to stall the car, if that helps!. it eases of if i put my foot slightly on the clutch and then i can carry on but as you can tell, the problem is irritating me. I have put fuel injector cleaning fluid in to see if it was a problem with the injectors with rubbish in them, but doing the miles i do it would have sorted the problem out. so, thank you for your help. hope i can get some response. Sarah Quote Link to comment Share on other sites More sharing options...
SandyCat Posted August 25, 2014 Share Posted August 25, 2014 Your car is a 1.3 petrol so it's not the normal diesel flywheel problems but I would be inclined to think it's still the clutch/flywheel that is vibrating because you say it reduces if you slightly press the clutch pedal. May also be worth getting the engine mountings checked. Quote Link to comment Share on other sites More sharing options...
DieselPig Posted August 25, 2014 Share Posted August 25, 2014 Sarah, If your mechanically inclined check the clutch pedal switch in the pedal box. If you put your foot on the clutch and it clears the fault the switch may have a bad connection. Quote Link to comment Share on other sites More sharing options...
