Addyshan Posted December 18, 2015 Share Posted December 18, 2015 I've got a mk7 titanium with the rear parking sensors. I don't think they work when I put the car in reverse it beeps once and that's it. I reversed back close towards a car no sound at all. I fought with the parking aid that when I put it in reverse there is a consistent which would beep faster the closer I got to the object behind is that right. Quote Link to comment Share on other sites More sharing options...
Russ Posted December 18, 2015 Share Posted December 18, 2015 Once the sensor detects something behind the car it beeps faster the closer you get to the object. Quote Link to comment Share on other sites More sharing options...
m1tch Posted December 18, 2015 Share Posted December 18, 2015 If it goes 'crunch' its too close, it should start beeping as you move closer to something behind you, how close are you getting? Might be worth double checking the wiring to the system. Quote Link to comment Share on other sites More sharing options...
iantt Posted December 18, 2015 Share Posted December 18, 2015 Ign on , engine off, select reverse and walk up to each sensor in turn and listen if each or any bleeps , easier to listen with boot open Quote Link to comment Share on other sites More sharing options...
Addyshan Posted December 18, 2015 Author Share Posted December 18, 2015 Only got the car from the ford dealer yesterday. No I've been reversing up to a parked car very close no sound at all I've cleaned the sensors as its raining. I will walk up and check each sensor, can I just put my hand close to each sensor to see if it works. I think it will be for the dealer to sort out as I'm not messing about with wiring. I fought it would be the case if I got closer it a object it would start beeping faster. Was only asking because I fought there might some sort of setting in the car I may have accidentally turned off. Quote Link to comment Share on other sites More sharing options...
karl46 Posted December 18, 2015 Share Posted December 18, 2015 Yes. If you have just got the car from a dealer then if it's broken it's up to them to fix under the sale of goods act. 1 Quote Link to comment Share on other sites More sharing options...
