Beth G Posted March 8, 2017 Share Posted March 8, 2017 I am looking to do an oil and oil filter change on my 63 plate 1.5L Ford Fiesta. Does anyone have a picture or diagram of where the drain plug and filter is on this engine? I did it to my 2000 fiesta no problem but the engine was much easier to see on that. Quote Link to comment Share on other sites More sharing options...
isetta Posted March 8, 2017 Share Posted March 8, 2017 diesel I assume. based on my fiesta diesel, filter is on the front of the engine (Between engine block and radiator)at the gearbox end. it sticks up at about 45 degree angle . It is not a metal can type. You unscrew the black plastic cap and pull out the paper element. when you put new element in, there is a protrusion at the bottom of the filter that must locate in a hole in the bottom of oil filter housing , this can be fiddly as the wall of the housing stops you being able to see if you got it in correctly. If I remember correctly the sump plug is the middle of the sump and the bolt goes vertical up into it. Well, I say in the middle, I think it was towards fan belt end (but it is not one of those on the edge of the sump like some are). On my older 2007 fiesta 1.6tdci I ended up stripping the sump thread after about 10 oil changes. It was steel bolt into steel sump but I think the length of the thread in the sump is not great. I suppose I was overtightening it when trying to be sure it would not leak around the copper washer. Judging by the supply of replacement sump pans on eBay I think others people may be doing that also. I do not know for a fact the 1.5tdci is exactly the same Quote Link to comment Share on other sites More sharing options...
