ScaniaPBman Posted August 22, 2017 Share Posted August 22, 2017 As the title says, when you return to your keyless car and find the battery flat, how do you get in to release the bonnet and access the battery? Is there a concealed + & - socket somewhere? Do you have to break into the vehicle external wiring harness somewhere and power the central locking solenoids from an external source? For me this is an acedemic question since I only own cars with an old fashioned metal key and external keyhole, but on examining a recent Renault parked next to me yesterday there was no keyhole to be seen anywhere. ScaniaPBman. Quote Link to comment Share on other sites More sharing options...
iantt Posted August 22, 2017 Share Posted August 22, 2017 On fords there is a concealed driver's door lock barrel ,and key inside the remote fob 2 Quote Link to comment Share on other sites More sharing options...
yunii Posted August 22, 2017 Share Posted August 22, 2017 On the focus when remote battery is dead you remove cover on ign barrel to slot in key & then you press clutch & press push start engine button this key slots out of the remote as mention. Prize out cap with thin flat screwdriver to reveal ign barrel.YuniiSent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
jimbojambojumbo Posted August 22, 2017 Share Posted August 22, 2017 Just now, yunii said: On the focus when remote battery is dead you remove cover on ign barrel to slot in key & then you press clutch & press push start engine button this key slots out of the remote as mention. Prize out cap with thin flat screwdriver to reveal ign barrel. Yunii Sent from my SM-G925F using Tapatalk doesnt explain how you get in the car in the first place my focus rs does not have a key blade hidden in the fob? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 22, 2017 Share Posted August 22, 2017 There will be a key blade somewhere in the key.This type has a blade that pulls out of the top-http://www.ebay.co.uk/itm/331571545440This type has a blade behind the back cover-http://www.ebay.co.uk/itm/252946417714Sent from my SM-G930F using Tapatalk 3 Quote Link to comment Share on other sites More sharing options...
yunii Posted August 22, 2017 Share Posted August 22, 2017 This is the keySent from my SM-G925F using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
isetta Posted August 22, 2017 Share Posted August 22, 2017 I would be thinking maybe this way, but you need a charged car battery beside the car. Jack car up enough (and support) so you can get to the cable on the starter motor - the think heavy duty cable that goes from car battery to the starter motor. run a wire from negative battery terminal to the ground of the car (like the engine or gearbox casing). run a wire from the positive battery terminal to the thick cable on the starter motor (the one that goes to the battery in the car). best to do this carefully whilst you get someone else to operate the remote and open the door AS YOU MUST MAKE SURE YOU DO NOT SHORT CIRCUIT. If anyone can think of a reason why this would not be OK, please say Quote Link to comment Share on other sites More sharing options...
iantt Posted August 22, 2017 Share Posted August 22, 2017 good luck with that with an under tray most cars are fitted with nowadays. and on a rainy day. lol 2 Quote Link to comment Share on other sites More sharing options...
biff55 Posted August 22, 2017 Share Posted August 22, 2017 getting into a keyless car with flat battery you say ? no prob , got this well covered , now can someone hold my beer a moment....... :-) 3 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 22, 2017 Share Posted August 22, 2017 With the emergency key blade you can get into a car with a flat battery even if double locked.Only the drivers door will open though.Sent from my SM-G930F using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Ken.K Posted August 22, 2017 Share Posted August 22, 2017 On my Lexus you can lift open a panel on the door handle insert the key into a slot to pop it out. Look under your door handle you should see a small slot Sent from my HTC 10 using Tapatalk Quote Link to comment Share on other sites More sharing options...
DJ_Andy_M Posted August 23, 2017 Share Posted August 23, 2017 What about on the MK3.5? We have different keys, still got the blade but there isn't the ignition cover I can remove either. Quote Link to comment Share on other sites More sharing options...
iantt Posted August 23, 2017 Share Posted August 23, 2017 You don't need to, there's a position in centre console I believe that you place the fob 1 Quote Link to comment Share on other sites More sharing options...
ace666 Posted August 23, 2017 Share Posted August 23, 2017 https://owner.ford.com/how-tos/vehicle-features/locks-and-security/intelligent-access-with-push-button-start.html this tells you how to get into the car if your battery in the fob is dead. Regards Adam Quote Link to comment Share on other sites More sharing options...
shazbat123 Posted July 12, 2019 Share Posted July 12, 2019 have a ford mondeo 2008 battery flat keyless not working (new battery tried) no emergency key anyone help?? Quote Link to comment Share on other sites More sharing options...
andypsp Posted July 13, 2019 Share Posted July 13, 2019 14 hours ago, shazbat123 said: have a ford mondeo 2008 battery flat keyless not working (new battery tried) no emergency key anyone help?? have looked inside keyfob to see if the spare keyblade is inside. 2 Quote Link to comment Share on other sites More sharing options...
Ted Sloan Posted August 15, 2021 Share Posted August 15, 2021 If it’s the pear shaped remote it is behind the Ford badge on remote if you squeeze the two striped recesses at narrow end of fob the Ford logo lifts up revealing key behind it Quote Link to comment Share on other sites More sharing options...
unofix Posted August 16, 2021 Share Posted August 16, 2021 Hello Ted, Sharon will be pleased to know the answer, she's been unable to use her car for 2 years 🤣 2 Quote Link to comment Share on other sites More sharing options...
