Stonemotions Posted May 19, 2019 Share Posted May 19, 2019 I have got an oil leak on the car and had a look underneath. Although visibility is limited I think the leak is coming from the item circled in red. The pictures attached shown an engine from the front, with the item in question located at the back right. The other picture highlighting the particular item in question. Can someone identify what that item is? Thanks Quote Link to comment Share on other sites More sharing options...
mkaminski100 Posted May 23, 2019 Share Posted May 23, 2019 High pressure fuel pump.Sent from my Pixel 3 XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
Stonemotions Posted June 19, 2019 Author Share Posted June 19, 2019 Had a garage look at in the end, turned out to be a leak from the camshaft carrier which required a new gasket, with a further coolant leak established from the coolant pump. I had a single instance of the leak causing a burning smell and a bit of smoke come from the back of the engine which is why I went and had it checked. Was an expensive bill but at least its sorted. Quote Link to comment Share on other sites More sharing options...
