ByteSlinger Posted January 10, 2020 Share Posted January 10, 2020 I'm trying to update my Sync 3 from version2.2 but the update download that the Ford website keeps spiting out to me (SYNC3_2815874155_Update) has two files inside the 'SyncMyRide' folder that won't unzip as they are corrupted. I've tried downloading it several times on different devices (both Windows and Mac) and none of them can extract those two files. Has anyone else experienced this or found any way around this? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 11, 2020 Share Posted January 11, 2020 Are you trying to decompile the compressed files in the folder?The files should be laid out in this format only-SyncMyRideAutoinstallDONTINDX.MSANo further unpacking is needed as the SyncMyRide folder is self extracting and processed by the car's installation system itself.Any attempts to extract the files prior to plugging into the car will result in an installation error due to file structure disparity with the autoinstall file.Sent from my SM-G965F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
pwhite144 Posted June 15, 2020 Share Posted June 15, 2020 I have the same problem trying to update my 2014 F-150. The file that downloads from the Ford website won't unzip because the Zip file is corrupted. I did the same thing, tested it with WinZip and tried to repair it but no dice. Ford's "support" person was absolutely clueless and had no desire to help. He only knew that the system wasn't supposed to be having any problems. ????? He wouldn't even test the file for himself. He had no idea what he was doing and no desire to figure out the issue. So aggravating... Quote Link to comment Share on other sites More sharing options...
nicam49 Posted June 15, 2020 Share Posted June 15, 2020 17 minutes ago, pwhite144 said: I have the same problem trying to update my 2014 F-150. The file that downloads from the Ford website won't unzip because the Zip file is corrupted. I did the same thing, tested it with WinZip and tried to repair it but no dice. Ford's "support" person was absolutely clueless and had no desire to help. He only knew that the system wasn't supposed to be having any problems. ????? He wouldn't even test the file for himself. He had no idea what he was doing and no desire to figure out the issue. So aggravating... Hi, have you read the post previous to yours? I think it contains the solution... 1 2 Quote Link to comment Share on other sites More sharing options...
Tom77 Posted September 21, 2020 Share Posted September 21, 2020 On 6/15/2020 at 3:37 PM, nicam49 said: Hi, have you read the post previous to yours? I think it contains the solution... No, the proposed solution does not work. I am not able to decompress all files into the folder SyncMyRide from the main ZIP file which were downloaded. Solution? Quote Link to comment Share on other sites More sharing options...
Dave Eacott Posted October 9, 2020 Share Posted October 9, 2020 09 September 2020 SYNC 3 Map Update problems Hi, I have successfully updated the Sync 3 operating system, but am having trouble loading the new map data. I have downloaded the update 3 times and each time I find the DONTINDX.MSA file is missing. SyncMyRide Downloaded ok Autoinstall.lst Downloaded ok DONTINDX.MSA ***********This file is missing I have contacted Fords but am still awaiting a reply. This update is in two parts, and when I try to install it which takes about an hour for each part it fails and just seems to loop. I have followed the instructions and turned of the engine shut down, locked doors and waited two minutes between the parts.. I currently have map version 9, assume 10 will be the latest.? Can anyone help? Many Thanks Dave Quote Link to comment Share on other sites More sharing options...
Andyr55 Posted October 9, 2020 Share Posted October 9, 2020 F9 is the latest as far as I’m aware. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 9, 2020 Share Posted October 9, 2020 Map version 9 is the most up to date.If you really need the index file just create a blank text document then save it in MSA format with the DONTINDX filename.Sent from my SM-G965F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Comares2001 Posted October 9, 2020 Share Posted October 9, 2020 1 hour ago, Dave Eacott said: 09 September 2020 SYNC 3 Map Update problems Hi, I have successfully updated the Sync 3 operating system, but am having trouble loading the new map data. I have downloaded the update 3 times and each time I find the DONTINDX.MSA file is missing. SyncMyRide Downloaded ok Autoinstall.lst Downloaded ok DONTINDX.MSA ***********This file is missing I have contacted Fords but am still awaiting a reply. This update is in two parts, and when I try to install it which takes about an hour for each part it fails and just seems to loop. I have followed the instructions and turned of the engine shut down, locked doors and waited two minutes between the parts.. I currently have map version 9, assume 10 will be the latest.? Can anyone help? Many Thanks Dave Haha you'll probably wait 2 years to get F10 if Fords performance on this issue so far is anything to go by. Quote Link to comment Share on other sites More sharing options...
Maddave Posted October 9, 2020 Share Posted October 9, 2020 I have updated sync to the latest version , but still no map update ,still on f7,and the sat nav voice now stammers. Had this car 2 years never had a map update. I think Ford have lost the plot, no updates and now only offering 1 litre petrol engines. Will seriously be looking at Toyota next time I change cars, have always had Fords and have just turned 60. Quote Link to comment Share on other sites More sharing options...
StewartHarris Posted October 9, 2020 Share Posted October 9, 2020 9 minutes ago, Maddave said: I have updated sync to the latest version , but still no map update ,still on f7,and the sat nav voice now stammers. Had this car 2 years never had a map update. I think Ford have lost the plot, no updates and now only offering 1 litre petrol engines. Will seriously be looking at Toyota next time I change cars, have always had Fords and have just turned 60. I too had voice break up following update from 3.3.19052 to 3.4.xxxxx. If I said 'help' the voice would stop/pause briefly/restart (in the same place). I also experienced this break up on navigation. This has been discussed on a couple of other threads on this forum & on cyanlabs. I've just used the syn3updater on cyanlabs to downgrade/reformat & reinstall 3.4.xxxx with latest F9 maps. I tried other solutions - but this fixed the break up for me. Suggest you take a look at the thread 'Sync3' on this forum & go to cyanlabs (https://cyanlabs.net/) look in their community at a thread ' voice is ticked off/stuttering'. Quote Link to comment Share on other sites More sharing options...
Maddave Posted October 9, 2020 Share Posted October 9, 2020 Thanks for the quick reply ,will have a look over the weekend 👍 Quote Link to comment Share on other sites More sharing options...
Dave Eacott Posted October 9, 2020 Share Posted October 9, 2020 Hi, Thank you for your comments above. On further investigation, after god knows knows how much petrol I have used with the car sitting on the drive and going cruising, it appears that I am all up to date. In fact I have probably updated it all more than once, if that is possible 🙂 Ford Sync 3 is now V3.4 Navigation Maps now V9 I found the .xml file that tells you it is complete not at the top level of my usb stick but inside the SyncMyRide Folder. I also connected my car to my WiFi and checked for updates and It confirmed I am up to date. Hope this helps anyone else that is struggling Dave Quote Link to comment Share on other sites More sharing options...
Comares2001 Posted October 9, 2020 Share Posted October 9, 2020 3 hours ago, Maddave said: Thanks for the quick reply ,will have a look over the weekend 👍 Use the Alexp999 download for F9 maps. Its the same as offered by Ford on their website. Takes around 2hrs to install in car easily.Don't waste your life waiting for Ford you give it to you. 1 Quote Link to comment Share on other sites More sharing options...
Dave Eacott Posted October 12, 2020 Share Posted October 12, 2020 ORIGINAL POST 09 September 2020 SYNC 3 Map Update problems Hi, I have successfully updated the Sync 3 operating system, but am having trouble loading the new map data. I have downloaded the update 3 times and each time I find the DONTINDX.MSA file is missing. SyncMyRide Downloaded ok Autoinstall.lst Downloaded ok DONTINDX.MSA ***********This file is missing I have contacted Fords but am still awaiting a reply. This update is in two parts, and when I try to install it which takes about an hour for each part it fails and just seems to loop. I have followed the instructions and turned of the engine shut down, locked doors and waited two minutes between the parts.. I currently have map version 9, assume 10 will be the latest.? Can anyone help? REPLY FROM FORDS RECEIVED TODAY Good Morning David, I hope you are well. I forwarded your original concerns over to my technical department and sync specialists, I have been advised that the file avoids that Sync does index the USB content, e.g. looking for media files, such as MP3, However, if it claims this is missing, there is no issue. It may take slightly longer to download and update, however you can continue with the update, without the DONTINDX,MSA file, it will have no impact on the outcome. I hope this helps, however feel free to contact again if you continue to face difficulties. I HAVE NOw SUCCESFULLY UPDATED MY MAPS SYNC V3.4 Maps V9 Quote Link to comment Share on other sites More sharing options...
Eastof Posted May 13, 2021 Share Posted May 13, 2021 On 10/12/2020 at 1:24 PM, Dave Eacott said: ORIGINAL POST 09 September 2020 SYNC 3 Map Update problems Hi, I have successfully updated the Sync 3 operating system, but am having trouble loading the new map data. I have downloaded the update 3 times and each time I find the DONTINDX.MSA file is missing. SyncMyRide Downloaded ok Autoinstall.lst Downloaded ok DONTINDX.MSA ***********This file is missing I have contacted Fords but am still awaiting a reply. This update is in two parts, and when I try to install it which takes about an hour for each part it fails and just seems to loop. I have followed the instructions and turned of the engine shut down, locked doors and waited two minutes between the parts.. I currently have map version 9, assume 10 will be the latest.? Can anyone help? REPLY FROM FORDS RECEIVED TODAY Good Morning David, I hope you are well. I forwarded your original concerns over to my technical department and sync specialists, I have been advised that the file avoids that Sync does index the USB content, e.g. looking for media files, such as MP3, However, if it claims this is missing, there is no issue. It may take slightly longer to download and update, however you can continue with the update, without the DONTINDX,MSA file, it will have no impact on the outcome. I hope this helps, however feel free to contact again if you continue to face difficulties. I HAVE NOw SUCCESFULLY UPDATED MY MAPS SYNC V3.4 Maps V9 I have this problem too. Installs part 1 ok. Then asks for key start etc which I do. Then it just continually loops after I restart the car? How did you get past this? Quote Link to comment Share on other sites More sharing options...
