Wiring st150 heated seats into zetec s
It's the same switch that was used in the 2012 model Transits.
When pressed in the seats are off and the switch is less likely to be knocked. When the seats are on the button sticks out to draw attention that the seats are switched on (there should be a visible red ring when the button is sticking out).
  • Replies 52
  • Views 10.7k
  • TomsFocus
    TomsFocus
    I think that's also a symptom of leaving the seat heater on too long...
  • Arkhangelsk1989
    Arkhangelsk1989
    Spot on, cheers for all of the help, was quite easy to wire up, considering this is the first time I have dealt with wiring something I'm quite proud of myself 😂 couldn't have done it without the help
  • It's the same switch that was used in the 2012 model Transits. When pressed in the seats are off and the switch is less likely to be knocked. When the seats are on the button sticks out to draw a
I think that's also a symptom of leaving the seat heater on too long... :whistling:
Yes that's it, looks exactly like the photo when switched on 😁
