coolissimo Posted January 15 Share Posted January 15 Hi all, I just got a light on the dashboard, saying Tyre pressure malfunction. So not sure if I need to reset of replace the TPMS on the wheels or wheel. However can someone let me know how to reset the TPMS, on a Mondeo 2015, 2.0TDI, manual with push start button ??? And how can I check on Forscan which TMPS is not working properly? Thank you in advance. Quote Link to comment Share on other sites More sharing options...
unofix Posted January 15 Share Posted January 15 On 1/11/2024 at 11:08 PM, unofix said: If you're still on the original factory fitted tyre pressure sensors then the batteries will be going flat. The TPMS sensors are only expected to last 7 to 10 years depending on mileage. In this cold weather any batteries nearing the end of life will cause intermittent tyre pressure warnings. In all probability you are going to have to replace all of the TPMS in the coming year. 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted January 15 Share Posted January 15 Reset procedure in owners handbook. 3 Quote Link to comment Share on other sites More sharing options...
coolissimo Posted January 16 Author Share Posted January 16 Thanks mate Quote Link to comment Share on other sites More sharing options...
coolissimo Posted January 16 Author Share Posted January 16 20 hours ago, unofix said: Reset procedure in owners handbook. Thanks mate. I did manage to reset the TPMS light, with your help. Do you know if I can see the tyre pressure on the board cluster? or by enabling it on fordscan? I would like to be able to see not only the pressure but which TPMS is not working properly. Thank you. Quote Link to comment Share on other sites More sharing options...
unofix Posted January 16 Share Posted January 16 2 minutes ago, coolissimo said: Do you know if I can see the tyre pressure on the board cluster? or by enabling it on fordscan? I can't say either way. Some clusters do and some don't. Using FORScan you will be able to see which wheel is triggering the low pressure warning. 1 Quote Link to comment Share on other sites More sharing options...
Marty71 Posted January 16 Share Posted January 16 13 hours ago, unofix said: I can't say either way. Some clusters do and some don't. Using FORScan you will be able to see which wheel is triggering the low pressure warning. Was trying this with forscan on the wifes 15' same as op's car but couldn't find it any chance you got a quick 'how to' please. Quote Link to comment Share on other sites More sharing options...
coolissimo Posted January 17 Author Share Posted January 17 16 hours ago, Marty71 said: Was trying this with forscan on the wifes 15' same as op's car but couldn't find it any chance you got a quick 'how to' please. I am researching , when I do it will let you know. 1 Quote Link to comment Share on other sites More sharing options...
