Alexhol1999 Posted March 2 Share Posted March 2 Hi, Does anyone have any ideas on this? I have a 64 plate 1.6 diesel tdci. When I pull away in first gear and reach the biting point there is a loud noise that's like chewbaca 馃ぃ. It sounds like metal. It's not a squeak its more deeper like a oooo noise. It only happens every known again and not in any other gear.聽 I have replaced the calipers pads and discs. Also replaced the driveshaft (right side). The clutch feels absolutely fine, smooth through the gears. My next thought is auxiliary belt or crankshaft pulley. I'm really not sure what the problem is. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
unofix Posted March 2 Share Posted March 2 2 hours ago, Alexhol1999 said: My next thought is auxiliary belt or crankshaft pulley. I'm really not sure what the problem is. Use the force young Jedi 馃槈 Quote Link to comment Share on other sites More sharing options...
RichT. Posted March 7 Share Posted March 7 I have the same problem on my 63 plate, but I also get it in reverse. Tend to find its worse with steering input. Never been able to describe it and someone understand what I mean. I knew exactly what you meant when I read the title though. I had mine serviced shortly after it started. Changing the belt made no difference. Would be interested to know if you find a fix.聽 Quote Link to comment Share on other sites More sharing options...
