jake42O Posted March 29 Share Posted March 29 Hi all, I'll try keep it short. Bought a ford focus zetec mk2 1.6 TDCI engine G8DD purely as a project car to rebuild the engine. Got a lot of help from haynes manual, I'm not a mechanic I just love cars and enjoy learning about them...anyway engine is rebuilt and back in the car. Of course it cranks but won't start 馃槖聽 I do have a topdon topscan so I plugged that in to see if anything popped up. With key on engine off I got no codes but wondered if any one can help with the live data as I don't fully understand it. I have a few screen shots to see if anything obvious stands out to anyone. My first thoughts were to look at fuel so I should mention parts replaced during rebuild -聽 Fuel rail with sensor (refurbished). HPFP with sensor (refurbished). Fuel filter (new). Cam & crank sensors (new). Timing belt, water pump, idler, tensioner (new). Main & big end bearings (new). Piston rings (new). All seals, gaskets, o-rings (new). Glowplugs (new). Slave cylinder (new). Air filter (new). Head bolts, flywheel bolts, pulley bolt (new) Everything primed & bled. Any ideas would be appreciated before I start tearing it apart again 馃榿 thank you! Quote Link to comment Share on other sites More sharing options...
