dukesdave Posted July 30, 2011 Share Posted July 30, 2011 :( Hi all need some help please. the cam belt snapped today on my '97 1.4i escort,i was at the time just pulling into a space in a car park so at max was only doing 5mph. there was no noise,bangs or rattles it just died,as if it had ran out of fuel,or stalled. however i did try and turn it over and try to start it before i knew it was the belt,it turned over fine still with no noises. in your vast wisdom is the outcome looking very hopefull,or is escort doomed? any advice welcome as im not mechanically minded. Quote Link to comment Share on other sites More sharing options...
mr pompey Posted July 31, 2011 Share Posted July 31, 2011 Uve probbly bent the values in doin what uve done, With out talkeing the head off, u cant tell how much damage has been done, As u might have damaged the pistons to, Quote Link to comment Share on other sites More sharing options...
lublin Posted July 31, 2011 Share Posted July 31, 2011 I would get the engine leak-down tested as this will tell you if you need to take the head off or not. You don't need the cambelt attached to do a leak-down test as the air is blown in when the valves are at Top Dead Centre (unlike a compression test) and I think we can safely assume that valves are now in the closed position, unless they are bent, of course. No engine gives a 100% leak free reading and a main dealer, or tuning garage, should be able to tell you what is normal for a Ford Escort. http://en.wikipedia.org/wiki/Leak-down_tester Quote Link to comment Share on other sites More sharing options...
dukesdave Posted August 3, 2011 Author Share Posted August 3, 2011 Hi a big thanks to you all for your help,been to local garage they want at least £600,cant afford that so im going to cut my losses and sell it on eBay. so if anyone interested,im near lincoln and open to offers. heres some details: 1997 1.4i cl 80,000 miles m.o.t 30-11-11 tax 30-11-11 just had new downpipe and lambda sensor,front brake hoses and pipe HI ALL.HERE IS THE eBay ITEM NUMBER FOR THIS CAR 150642326579 Quote Link to comment Share on other sites More sharing options...
