anita- Posted February 15, 2009 Share Posted February 15, 2009 Hi, second problem! Im pretty sure the clutch bearing has gone, when the clutch isnt engaged when stationary there is a "whirring" noise, when the clutch is engaged it seems to dissaper. I have noticed a couple of times when pulling away in all gears at low revs there is an unusual noise. Would i be correct in thinking its the thrust bearing? Also what i am not to sure about is that the clutch has slipped whilst in gear a couple of times, noticable third and fourth and usually when coming of a roundabout. Its definitly feeling and sounding like the clutch isnt biting theres no pull. The thing is it doesnt do it all the time, hardly at all. and it seems to pull well in fifth gear from quite low down. could it be related to the first problem? Thanks in advance, would really appreciate help as only had the car for a week. Quote Link to comment Share on other sites More sharing options...
mintalkin Posted February 15, 2009 Share Posted February 15, 2009 you are right in saying it sounds like the thrust bearing starting to break down, replacement is the only option and you might as well do the clutch why the box is removed. Quote Link to comment Share on other sites More sharing options...
