Help Please Poss Immobiliser Problem?
Mk6 Fiesta 1.25 petrol 2004
So I was driving along then all of a sudden every warning lights come up on the dash including the immobiliser light wich is flashing fast. So I pull over and pop the bonnet everything seems ok water oil ect,
Then I get back in and try to start the car and it won't start it also won't bump start or jump Start all the warning lights are still on .
I have checked all the fuses and have tried to disconnect the battery for 20mins then reconnect put in radio code and still all tge warning lights are on and it won't start.
I have found a way to bypass it and get it started by pulling out the bottom relay under the glove box and plugging it back in fast whilst holding the key in the start position , this allows me to start and drive the car but with no speedo , no Rev counter and all the lights flashing this will do me for today but I need to find out the problem ASAP
Any help appreciated Thanks
Bump
post-38155-0-89740400-1373566056_thumb.j
Please help :)
So far I have had it plugged in coming up flash code 16 can anyone tell me what this is?
Have checked fuses
Have disconnected the ecu
Have disconnected the battery
Have removed the dials
Still same problem
