Arceye Posted March 14 Share Posted March 14 Hi folks New boy here with a 2010 Titanium 1.6. Rear springs are on an MOT advisory, I have to do the bushes so while the bits are on the floor I'll change the springs as well. Fords want £64 per spring for rears and £120 for fronts. There do seem a lot of cheaper options online but I'm sure the £10 springs wont last long! Does anyone have any recommends for a good sensible make or price, car has done 85k. Thanks Arceye Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted March 15 Share Posted March 15 I'd be tempted to just put Ford's on, they've lasted this long Quote Link to comment Share on other sites More sharing options...
orangecurry Posted March 15 Share Posted March 15 I chose Eibach - under 60 GBP for the front pair. Quote Link to comment Share on other sites More sharing options...
orangecurry Posted March 15 Share Posted March 15 15 minutes ago, DaveT70 said: I'd be tempted to just put Ford's on, they've lasted this long The problem I always have with your very sensible answer, is that on a 14 year old car, how do we know if Ford today obtain the same quality of part as they did 14 years ago? ...and which company makes springs for the 2010 Fiesta, as it certainly won't be Ford. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 15 Share Posted March 15 The car may be on it's second set by now. Don't forget Eibach springs are technically lowering springs. They don't give much drop, but if you're only doing the rears then it could end up sitting at a weird angle. I am also a fan of Eibach quality if changing all four though. Ford offered Eibach springs as an aftermarket upgrade for many years. (Not sure if they still do.) Tbh I'd be tempted to try the £10 springs if staying at standard height. There's no tyre risk if a rear spring spring snaps (unlike fronts) and they're easy to change as well. Quote Link to comment Share on other sites More sharing options...
orangecurry Posted March 15 Share Posted March 15 23 minutes ago, TomsFocus said: Don't forget Eibach springs are technically lowering springs. They don't give much drop, but if you're only doing the rears then it could end up sitting at a weird angle. I would have thought that Eibach manufacture both the correct replacement springs, whether it was the 'sports' or 'standard' suspension height/rate from the factory? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 15 Share Posted March 15 2 hours ago, orangecurry said: I would have thought that Eibach manufacture both the correct replacement springs, whether it was the 'sports' or 'standard' suspension height/rate from the factory? Eibach only make lowering springs. The Eibach springs are still an upgrade over sports suspension as well. Eibach®* Suspension-Lowering Kit with fitting 35150004 Fitted (ford.co.uk) Quote Link to comment Share on other sites More sharing options...
orangecurry Posted March 15 Share Posted March 15 Every day is a learning day. The Zetec-S has lowered/sports springs from the factory, so that's how I ended up with Eibachs as an option. OP - stick your registration into Autodoc and see what appears. Quote Link to comment Share on other sites More sharing options...
orangecurry Posted March 16 Share Posted March 16 21 hours ago, TomsFocus said: Eibach only make lowering springs. Now😁 I'm really not sure about this...... I just looked on Auto doc - for a Zetec-S replacement, and just Eibach, they list: Eibach R11709 Coil spring - Front Axle, Coil spring with constant wire diameter, for vehicles with lowered suspension Eibach Single Spring ERL (OE-Replacement) R10198 Coil spring - Front Axle, Coil Spring, for vehicles with standard suspension and upgraded Pro-kit version EIBACH Single Spring Pro-Kit F11-35-020-01-VA Coil spring - Front Axle, Coil Spring, for vehicles with sports suspension (same three options for the rear axle as well), so it looks like Eibach provide replacement for standard and lowered/sports for the Zetec-S.... whether that translates to a non-S, or is simply confusing naming convention, is easy to find out if the OP puts his car details into Autodoc. 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 16 Share Posted March 16 8 minutes ago, orangecurry said: Now😁 I'm really not sure about this...... I just looked on Auto doc - for a Zetec-S replacement, and just Eibach, they list: That is interesting. 🤔 I wonder if they're rebranded but made by someone else. It's not possible to order standard springs through the Eibach website. They only offer the option of Pro-Kit springs or Pro-Street coilovers. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 16 Share Posted March 16 21 minutes ago, orangecurry said: Now😁 I'm really not sure about this...... Turns out it is a brand new line. They're called ERL - Eibach Replacement Line - and seem to have only been launched within the past few months. So I guess we were both right... Eibach Replacement Line (ERL) Launch! - Eibach (deal.town) 2 Quote Link to comment Share on other sites More sharing options...
Arceye Posted March 25 Author Share Posted March 25 Thanks for your help guys. I bought the Eibachs from Autodoc. Cheers, Arceye 1 Quote Link to comment Share on other sites More sharing options...
Craigfez Posted 3 hours ago Share Posted 3 hours ago Anyone know if the zetec s springs will fit the Titanium tdci 1.6? Zetec s 2010 Titanium 5 door 1.6 tdci 2009 Many thanks in advance Quote Link to comment Share on other sites More sharing options...
