Fiesta St2 Hid Kit Help Required
Interferance problem is gone ;) new bulbs, plus 8 ferrite cores to block emi and complete his ballast earthed and new neg cable ran in just for it and looks great and also my radio sounds amazing!!! Woo thanks for your help phil also located my ballasts the same place you did cannot see one cable at all looks smart as :) cheers peps
  • 1 year later...
  • Replies 68
  • Views 16.1k
  • 4300k HIDS :)
  • Rotate the holder with the bulb in and it works
  • Where am I going wrong :( Here's some loverly piccys of what I'm struggling with. The original holder The bulb in the original way Bulb upside down and won't fit. The bulb / unable to turn
Was it worth the hassle D13? - What is the new neg cable run in // I wouldn't have a clue about all this .. With the benefit of hindsight and bearing in mind I have never taken a car apart what kit should I buy for a late 2009 titanium? (It has projectors).
Also I clicked yout car for sale link and saw your rear lights which I'm thinking are these?
http://www.ebay.co.uk/itm/261814177402?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
KNow anything about Tunigsportparts, the seller? I recon they'll look sweet on mine, which is sea blue!
I had an issue with a set of 55w hids I bought where they would come on for around 20 seconds then turn off. I had a canbus system on the 55w then got a standard 35w set and have had no problems since :)
Same with mine 55w set from my ZS flickered then went out 35w work fine on the ST
Yh it was worth it made a huge difference havnt a clue what caused it just the magnets sorted out any interference and the coppers helped to some say they don't some say they do but it helped mine never had a problem since, I'd go with hids direct 4300k h7 get quality that way and yh car sold ages ago but the lights will look good
  • 4 months later...
  • 3 weeks later...
Can anyone help me please?
Mine hasn't got the wire that holds the bulb in but instead a metal holder that also clips the electrical wires in it. There isn't anyway I can see how to hold a hid bulb?
Stu
Stu
You're not trying to plug HID bulbs into the stock bulb connector are you?
HIDs require Ballasts. They will not run of 12v.. they need almost 24000 volts peak to ignite
The original holder
The bulb / unable to turn the base
It needs to look like this.
No I have got a kit that I had in my previous car..
Problem is my holder is nothing like the ones I have seen on here..
Stu
Stu
After looking, the connectors you're comparing to are the connectors from the ballast to bulb.
Pretty much ALL cars (except those with HIDs, although some factory ones are similar) have the same headlight plug.
You either 1.) Run a relay system, which involves running a pos & neg wire to the ballast & then use the factory headlight connector as a signal wire
Or 2.) Run the ballast off the original headlight connector, which is what I now do having tried it both ways (the joys of precanbus!)
My retrofitted Projectors take a power from the Hi/low terminal then use the common neg from the plug to determine where the solenoid needs to be. The ballast just takes power regardless if the headlights are switched on
Hi and thanks for the reply..
No it' the holder itself that is the problem.
xenon-hid-h7-low-bulb-base-holder-adapte
Has you can see the wire connector is built into it but that does pop off,, but the wires on the HID Bulb won't go through the opening on the holder..
Only way round it that I can see is if I put a small cut in the holder so I can open it and fit the wires through that way..
Stu
Stu
I understand now!
I'd go with the plan of snipping a slight cut in it then passing the bulb through :).. that's of course I'd you're sure its the correct bulb.
Sent from my HTC One_M8 using Tapatalk
I haven't read all of the thread, but I did have to snip my holders to get my HID wires through. You can get these off eBay with the gaps already made if you'd rather keep your originals in pristine condition!
What have I mist here
What type of bulbs are they and where do they go?
I had the exact same problem, also had to snip a piece out to make it fit
after cutting it out it worked perfectly
H7 light bracket
HID
010
I'm running 6000k (was 8000k, but were too blue), 35w DC - no issues at all!
Sorry guys, what are the adapters for? I've never those before.
When I fitted my hids I used a H7 kit.
