Help Needed Guys
Thought id do a little service at home , started with fuel filter and thats where its stopped , got air in system and wont start how do I bleed , with nothing to bleed it with ?
Sent from my GT-I9505 using Ford OC mobile app
Solved by painterman
  • Replies 115
  • Views 10.4k
  • martyntdci
    martyntdci
    brim your filter, use a syringe and pipe to get it to the max... take off your in feed to the filter, chuck ya mouth round it n suck the derv through... (this literally takes around 30 seconds) very q
  • I have always had great success using a syringe and forcing fuel into the top of the filter.. None of this 40 minute faffing around
  • painterman
    painterman
    with the final suck ive done it , sorted , thanks for all your input guys :-)
you can't basically,you need the hand pump.these are a pig to change and a lot of people get stuck on em including me lol.
i called someone out in the end and it still took em 40 mins to start,they just kept cranking it until it started which I doubt was correct though :/
that's not what I wanted to hear on a Saturday evening when everywhere is closed :-(
I called a mobile mechanic out,you might get lucky at this time but I doubt it.
mine happened on a Sunday afternoon,
so basically I'm stuff without professional help ?
1st, did you replace the o ring in the top of ur filter housing? 2nd did you brim the filter to the top?
yes replaced the o ring,some spilt out when took old filter out so it wasn't to the top
Hi mate I did mine 2 days ago I used a syringe and filled the lines up with fuel took some messing around but of it started in 20 mins
brim your filter, use a syringe and pipe to get it to the max... take off your in feed to the filter, chuck ya mouth round it n suck the derv through... (this literally takes around 30 seconds) very quickly connect it bk on top of the filter housing... make sure your battery has a good charge.... then just crank... you may need crack open injector/s to bleed the air out though, instead of forcing it into the block
I have always had great success using a syringe and forcing fuel into the top of the filter.. None of this 40 minute faffing around :lol:
Thanks guys now going on the hunt for a syringe :-)
you will get one in a stationary shop,
Can be bought for refilling ink in printer cartridges or for using glue in model shops,
Just dont try use em full of silicone lol it ends in A+E with stitches like me
now gonna go to tescos as baby calpol has a syringe in box, and get fuel to top up with , hope this works .
sweet boil up the calpol and crystalise it too,
Waste not and all that lol
Any excuse to buy calpol! Does it still taste as good as it used to?
ive moved on to Redbull same great taste but less sugar :lol:
too damn sweet for me im afraid, still cant get this poxy car to start , had to connect the van to it now as ive deadened the battery
!Removed! nora, must of been cranking it for a while..... must be quite a bit of air in it..... did you suck it from the tank?
sucked on the end that feeds into the top , is that the right one ??
  • Solution
yeah.. it should eventually start.....
what i did was, take of filter cap.... pull out filter housing clean it.. soak filter in derv before placing in housing.... replace o ring on inside of housing cap... top up housing then re-connect to the cap...... re-fit..... open up bleed nipple and force derv inside until it comes out of the nipple, close nipple.... take off in-feed suck from tank (spit out derv lol) re-connect asap.... make sure batt has great charge....... dont crank over.... turn the key to (where warning lights are) about 7 times, whilst pumping the pedal...
then start cranking.... this worked for me... took around 40 mins from start to finish..... but im no professional mechanic, just a home taught d.i.y'er
Jesus is this thread still car related all this talk about sucking, twisting nipples and tryin to get her goin, :lol:
you wana join in lenny? more than welcome lmao
the only nipples i know these days are no longer twistable Mart,
If my woman was a diesel shed be an 87 Diesel Lada not a hope of a suck or gettin er goin :lol:
So yeah im in bro!
