BigRog Posted May 26, 2014 Share Posted May 26, 2014 As title guys, anyone suggest a polish and/or a wax that leaves no trace on black plastic and rubber. I have just spent 3 hours with an erazer taking the residue off after using "FinishKare 1000P". Your input will be much appreciated. Quote Link to comment Share on other sites More sharing options...
alexandjen Posted May 26, 2014 Share Posted May 26, 2014 Autobrite Cherry Glaze polish for me Quote Link to comment Share on other sites More sharing options...
weenatfergy Posted May 26, 2014 Share Posted May 26, 2014 Meguires liquid wax is supposed to leave no white residue! I haven't tried it yet but check out their YouTube videos Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
kristriple Posted May 26, 2014 Share Posted May 26, 2014 As title guys, anyone suggest a polish and/or a wax that leaves no trace on black plastic and rubber. I have just spent 3 hours with an erazer taking the residue off after using "FinishKare 1000P". Your input will be much appreciated.Autoglym's bumber gel gets rid of it no probs. Have you tried that instead of the eraser?Sent from my KFTT using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
BigRog Posted May 26, 2014 Author Share Posted May 26, 2014 Tried loads of stuff Kris, ended up using a "helix" rubber/erazer from asda 80p for 2, excellent I must say, it actually gets rid of the wax rather than masking it, also methylated spirits is brilliant, meths is the easiest to use as you can imagine, just rub it on and wipe off, the rubber leaves a mess but is equally good, when I say mess I mean it gets in all the grooves. Quote Link to comment Share on other sites More sharing options...
liam1984 Posted May 27, 2014 Share Posted May 27, 2014 I used to have this problem on my corsa, i used to use peanut butter! It brings black trim up like new and you can also snack while you work! Make sure its smooth peanut butter tho! Sent from my ST25i 1 Quote Link to comment Share on other sites More sharing options...
BigRog Posted May 27, 2014 Author Share Posted May 27, 2014 Thanx guys, after reading a few reviews here and there, I have decided to try the Autobrite Cherry Glaze, once again thanx for your responses. Quote Link to comment Share on other sites More sharing options...
gurcayy Posted May 27, 2014 Share Posted May 27, 2014 Cherry glaze is an AIO (all in one product) which means that it contains wax, but I recommend you to use additional sealant/wax over it if you want extended longevity. Quote Link to comment Share on other sites More sharing options...
BigRog Posted May 27, 2014 Author Share Posted May 27, 2014 Thanx for that, any recommendations please? Preferably one that doesn't leave any residue. Quote Link to comment Share on other sites More sharing options...
weenatfergy Posted May 27, 2014 Share Posted May 27, 2014 Meguires liquid wax is supposed to leave no white residue! I haven't tried it yet but check out their YouTube videos Sent from my iPhone using Ford OC Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
gurcayy Posted May 27, 2014 Share Posted May 27, 2014 It will be easier to recommend a sealant/wax if you could tell your budget. In addition, in my honest opinion, AF Tripple and Prima Amigo are far better AIO than Cherry Glaze. Quote Link to comment Share on other sites More sharing options...
BigRog Posted May 27, 2014 Author Share Posted May 27, 2014 I have the FinishKare 1000P on the car now as it's sealant, the reason I asked was that I didn't want to go through again what I've just had to do with the black trim covered in white residue. This cherry glaze will be a top up if you like, as for budget, if its good I don't mind paying, I'm a firm believer in if you buy cheap you buy twice. What about this Autoglym HD wax, does that leave residue? would it be ok to put on top of the cherry glaze? Quote Link to comment Share on other sites More sharing options...
gurcayy Posted May 27, 2014 Share Posted May 27, 2014 Okay... Firstly, If I were you, I wouldn't bother with another sealant if I already had FK1000p. It is a great last stage protection product that gives incredible durability and decent shine. Secondly, I used to use FK1000p in the past on my Focus and I had had issues with white residues on the trim if I only let it too long to cure on the trim. So, may be you have to reconsider your application method as I could see from your avatar your car don't have more trim/rubber than mine. What did you use to apply the wax? I am pretty sure if you don't get too close to the window rubbers and door trims or if you wipe off the residue immediately, you won't have any problems. Don't use cherry glaze over a wax or sealant as a top. It contains cleaners which will wipe off any previous layers of wax/sealant. Always apply in this order: AIO (Cherry Glaze) -> Wax/Sealant (FK1000p). 1 Quote Link to comment Share on other sites More sharing options...
BigRog Posted May 27, 2014 Author Share Posted May 27, 2014 First of all thank you for your time explaining all this to me. I used an applicator to apply the wax, I think what I will do is apply the cherry glaze over the top when it comes then re-apply the 100p. The finish isn't as good as I would like so like I say I will do it again. Quote Link to comment Share on other sites More sharing options...
martyntdci Posted May 27, 2014 Share Posted May 27, 2014 use the cherry glaze on a clean blanket if you will. then re-apply the 100p.... i use a couple of auto glym hand applicator's http://www.amazon.co.uk/Autoglym-PPARED4-Perfect-Palm-Applicator/dp/B002BETXS8 and it works fine, easily washable etc.... Quote Link to comment Share on other sites More sharing options...
BigRog Posted May 27, 2014 Author Share Posted May 27, 2014 So, dodo lime juice followed by cherry glaze then the 100p. cheers guys for all your help. Quote Link to comment Share on other sites More sharing options...
Philf1 Posted May 27, 2014 Share Posted May 27, 2014 I know what your going through Roger. Did mine last weekend and the white marks have appeared through the bumper care as it has washed off in the rain. Have tried the eraser thing and despite working takes so much time. Guess the best option will be to very careful applying the polish and wax in future. Anyone know if white spirit works? Only wondering as I have loads in the garage. Quote Link to comment Share on other sites More sharing options...
BigRog Posted May 27, 2014 Author Share Posted May 27, 2014 I read somewhere if using white spirit water it down 1:1 I used meths after the erazer just to make sure I got rid of it. Good luck :) Quote Link to comment Share on other sites More sharing options...
J14BRU Posted May 28, 2014 Share Posted May 28, 2014 I just used veg oil to get rid of the residue on my trim, car has been washed three times since and the white hasn't come back. Quote Link to comment Share on other sites More sharing options...
