Eddicus Posted May 31, 2014 Share Posted May 31, 2014 Hi, I've recently bought a mk5 fiesta, due to my mk6 being written off. I was wondering if the front discs/calipers/carriers from the mk6 would fit straight onto the mk5? As the mk5 runs 240mm and the mk6 runs 260, so I'd get a stress free brake upgrade? Thanks Ed Quote Link to comment Share on other sites More sharing options...
Jake90087 Posted May 31, 2014 Share Posted May 31, 2014 Honestly I would air on the side of caution and say no. The mk6 had things like ABS as standard and the mk5 had it only on top spec models... The brakes on a mk5 aren't all that had when they're new anyway, decent pedal feel with nice progressive action and the car has a way of telling you when you're about to lock up. But I say go for the standard parts. The mk5 isn't a big car. Sent from my iPhone 5 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Jake90087 Posted May 31, 2014 Share Posted May 31, 2014 To add something else I've just realised. The Zetec-S (hot mk5) had 260mm vented discs. That could be a shot to you. My freestyle has as set of vented ones which is why I found they perform well. Especially at motorway speeds. Now I'm not sure what car you have but this bloke is excellent. Give it a read. http://www.mwstewart.co.uk/articles/mk5finesse/ Sent from my iPhone 5 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Eddicus Posted May 31, 2014 Author Share Posted May 31, 2014 Thanks for the reply! The 260 is the size I wanna up to, you'd recommend vented as well? I just find my brakes quite sloppy really, they don't have the bite I'm after? I know ford aren't big on changing things all that much, so I was hoping for just a straight swap? I am thinking about a puma engine conversion at some point as well, so I'd need the bigger brakes then! Ed Quote Link to comment Share on other sites More sharing options...
Eddicus Posted May 31, 2014 Author Share Posted May 31, 2014 Nice car in the link as well! Looks good man! Ed Quote Link to comment Share on other sites More sharing options...
martyntdci Posted May 31, 2014 Share Posted May 31, 2014 start with changing your brake fluid... Quote Link to comment Share on other sites More sharing options...
Eddicus Posted May 31, 2014 Author Share Posted May 31, 2014 It's new fluid, did a complete service on it recently, brake fluid, coolant, gearbox oil, engine oil and filter, sparks, leads and coil pack, thought it was best to look after it! Ed Quote Link to comment Share on other sites More sharing options...
Jake90087 Posted May 31, 2014 Share Posted May 31, 2014 It's new fluid, did a complete service on it recently, brake fluid, coolant, gearbox oil, engine oil and filter, sparks, leads and coil pack, thought it was best to look after it! Ed Sounds like you're set. Also, what model do you have? I.e Zetec. If it's a 1.3 it will have solid discs, but the more sporting models have vented discs anyway. Not sure on the size but they're vented. Sent from my iPhone 5 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Eddicus Posted May 31, 2014 Author Share Posted May 31, 2014 Sorry, should have said! A 1.3 endura Ed Quote Link to comment Share on other sites More sharing options...
