jace1969 Posted March 8, 2015 Share Posted March 8, 2015 Hi all. Just got me a mobius v2 wide angle dash cam (on its way) and put the sofware in pc ready to set up. What lead do i need to plug into pc to get pic to set the angle of cam''live picture'' It says it comes with u.s.b video out cable but its got the mini u.s.b and a thin black conector on the other end. I have also got the old power lead off my other dash cam and a 5m u.s.b to mini u.s.b to use. Thanks Quote Link to comment Share on other sites More sharing options...
Celticfan Posted March 8, 2015 Share Posted March 8, 2015 If you connect the camera to a PC with a standard USB cable you can then use the software to set your camera up. Don't forget to set the 180 degree setting to allow the image to be recorded the right way up for viewing as the camera as standard is 'upside down'. The cable you receive with the camera enables charging, etc. Quote Link to comment Share on other sites More sharing options...
jace1969 Posted March 8, 2015 Author Share Posted March 8, 2015 Just read on a pdf manual that if you plug in u.s.b to p.c with no card its a webcam so can do set up on the angle in the car and put card in for taking files off etc,is this right. Also do you do the main set up with card in and i have a few u.s.b cables so these will be ok as 1 is 5 metre long for car going through a 5v output cigi adaptor. And i also have old cigi charger off old dash cam already wired in 5v. Quote Link to comment Share on other sites More sharing options...
