marsden94 Posted April 13, 2015 Share Posted April 13, 2015 Basically my car was driving fine no problems. Fuelled up with £10 was driving fine until after about 3-4 miles car slowly started to die wouldn't go past 3 1/2 revs now the car will only try an start if my foots on the accelerator then cuts out straight away I've checked the ignition coil spark plugs changed fuel don't know what else it could be any help greatly appreciated cheers Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted April 13, 2015 Share Posted April 13, 2015 When you turn the ignition on, can you hear the fuel pump priming? Quote Link to comment Share on other sites More sharing options...
marsden94 Posted April 13, 2015 Author Share Posted April 13, 2015 Yeah you can Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted April 13, 2015 Share Posted April 13, 2015 Have you checked the fuel filter? Air filter? As daft and Unrelated as it may sound, have you checked the oil and coolant? What's the mileage of the car? Quote Link to comment Share on other sites More sharing options...
marsden94 Posted April 13, 2015 Author Share Posted April 13, 2015 Yeah they all seem fine and I had a replace the engine it's done about 70 thousand miles Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
marsden94 Posted April 13, 2015 Author Share Posted April 13, 2015 Had new valves and the head skimmed and the water pump changed Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted April 13, 2015 Share Posted April 13, 2015 Ah okay. Timing belt look okay? Any dashboard warning lights? Have you tried connecting an OBDII fault code reader? Even just a 5pound eBay bluetooth job would do, that's what I use Quote Link to comment Share on other sites More sharing options...
marsden94 Posted April 13, 2015 Author Share Posted April 13, 2015 Yeah timing belts tight and yeah a friend of mine has the computer so just need to wait for him Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
marsden94 Posted April 14, 2015 Author Share Posted April 14, 2015 Anyone any other ideas Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Chrispugh21 Posted April 15, 2015 Share Posted April 15, 2015 Did you put the right fuel in? If the case was you put the wrong fuel in the original fuel will still be in the pipes and will cut out around 5 miles. That could be your problem Sent from my iPad using Ford OC 2 Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted April 15, 2015 Share Posted April 15, 2015 Wanted to suggest that but didn't want to sound an idiot or anything! Aha :) Quote Link to comment Share on other sites More sharing options...
marsden94 Posted April 16, 2015 Author Share Posted April 16, 2015 Yeah it was 100 percent the right fuel I cleared the system and put fresh fuel in Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Chrispugh21 Posted April 16, 2015 Share Posted April 16, 2015 By any chances is your fiesta a diesel due to a lot of cheap fuelling stations morrisons, tescos, etc... Have water mixed in with the fuel and probably that is your situation a lot of AA have colours all the time with this problem has been in the news recently Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
Chrispugh21 Posted April 16, 2015 Share Posted April 16, 2015 Call outs***** Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted April 16, 2015 Share Posted April 16, 2015 The O.P. states his car has spark plugs . . . won't be a diesel then ! :) Quote Link to comment Share on other sites More sharing options...
marsden94 Posted April 20, 2015 Author Share Posted April 20, 2015 When it starts its like the ecu tells it to stop straight away so it cuts out Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
MattDRX Posted April 20, 2015 Share Posted April 20, 2015 idle control valve. 2 Quote Link to comment Share on other sites More sharing options...
marsden94 Posted April 22, 2015 Author Share Posted April 22, 2015 should this seem blocked /stuck ? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
