Focus St Tdci
I have a deep impact blue one and i've never washed a car so much in my life :d
TBH with such a striking looking car keeping it clean is the least I can do.
(If only the flamin' seagulls would sod off ;) )
  • Replies 58
  • Views 12.8k
  • Stoney871
    Stoney871
    The DPF on the diesel ST are a lot better designed than earlier versions as they are Euro6 spec. The Euro4 spec needed Eolys fluid and the Euro5 had a tendency to not want to carry out a regen when n
  • Stoney871
    Stoney871
    Just to tempt you a bit more ;) -
Know how u feel with seagulls I live near a industrial estate where they nest on the roofs the buggers swoop and crap everywhere anyway forgot to see if the st has got start/stop or no?
Yes mate ST does have start/stop, however people do look at you weird when it does it haha!
How does it actually work does it come on automatically or shove it in neutral never had a car with it before
'Active City Stop' kicks in when you select neutral and apply the handbrake.
The engine cuts and a green A comes up on the dash screen.
Press the clutch and the engine restarts.
If the car power supply is taxed (aircon full blast or heated screens are on etc) then it will not kick in and the A will be greyed out on the dash.
If ACS is on and the car detects a power drop then the engine will restart itself without you touching anything.
You get a manual ACS deactivation button near the gearstick as well.
A nice touch is that if you stall by accident just push the clutch pedal down and the car will restart without having to press the start/stop button.
Same as mine but I opted for Nav to, must say harder to keep clean than I had hoped though!
Looks absolutely stunning.
Yunii
Also does the st3 come standard with the rear tinted windows?
Yunii
Thanks very much Pal!
No you will need to select privacy glass or ST Style Pack which give you the 19" wheels and Privacy Glass.
Back to the dpf regeneration how do you know when it's happening and would a 65 mile trip do the regeneration I roughly make about 290 miles a month which includes two 130 round trips then the rest is usually to shops or nearby towns
