Swirl Marks
there are products that will fill swirls in but they will only return if u give it a proper wash again so its worth cutting them out.
SRP wont get rid of you paintwork quickly at all.
  • Replies 53
  • Views 10.6k
SRP does cut - but it also fills, which is what you're after. You can't remove swirls or do any other form of correction without physcially changing the paint. Chemical Guys Swirl Remover is specifically designed for the job, but SRP is just as good.
i found chemical guys swirl remover to have much more cut than SRP.
SRP is much easier to use with hand application too. CG's is hard work by hand and can hologram if you dnt work it enough.
Only had the car 10 weeks think I am better leaving them and see if I add anymore or get better at washing / drying / waxing the car eh ??
Thanks all
