Mk3.5 Cruise Control Fitting
Some good info coming up here
so firstly, I haven’t checked the hex code as I did not know which line it needed to be on but now I have that info I will do
chris, mine is a 04/16 model so would be the latter. I’d be interested to know what the differences are!!
  • Replies 259
  • Views 176.8k
  • allsomatt
    allsomatt
    SUCCESS! INSTALL/UPGRADE COMPLETED CAN CONFIRM FULLY FUNCTIONAL CRUISE CONTROL AND SPEED LIMITER WORKING!  All for under £100.00 Fully OEM vs Third Party who wanted £500+ I cannot confirm if this
  • googled these images,  are mk3.5 images i found.
  • Cruise is now activated! After many failed attempts with both Focccus and Forscan, I managed to borrow someone's UCDS dongle and software and we activated cruise in minutes on my car. I tested it
On ‎05‎/‎12‎/‎2017 at 8:51 PM, Stoney871 said:
Have you checked the cruise control hex code in the BCM?-
Hi Clive,
I have a Focus MK3.5 March 2017, i can't seem to find that hex line code, have i missed something with Forscan? Also, can't find the BCM module or BCMii is the same?
As Focccus was unable to read te ECU i was putting my hopes in Forscan...
Do you think that the problem is the ELM cable?
Appreciate any help.
Paulo
With the several attempts i did with Focccus generated some DTCs , Forscan clear all but one, nothing litted in the pannel. I believe it is not possible to clear it, as it has to do with the Cruise Control switch, can anyone confirm that?
DTC - Set of switches incompatible with the vehicle.
I see now that it was a bad idea to put Forscan in Portuguese, should have let it in English, it would be easier for everyone else to read it... if that helps and someone knows how to change that, please tell me how to.
Thanks to all of you contributors to this topic, and especially to JW1982, i now have Cruise Control.
How did you manage it?
After the steering wheel in place, Focccus was unable to read my ECU. Forscan did it.
I was following instructions JW1982 to enable auto locking , thought this would be easy to a first time with Forscan, didn't get it done, yet. http://www.fordownersclub.com/forums/topic/97724-auto-locking-doors/
"Next go to the "Configuration" tab of the program (marked with a processor symbol). Now the program shows a list of different configuration options. Choose for CCC main and start the procudure to read the CCC.
Afbeeldingsresultaat voor Forscan CCC
Now the CCC configuration can be edited. When finished simply press "Write" to load the modified configuration into the BCM."
First i had a Forscan warning about low battery, then it was missing a vbf file in a specific folder. Only then i could reach to BCM Central Configuration.
Double clicked in Cruise control below value, set to with cruise control, a few lines below there's the ASL option, did the same, et voilá Cruise control is activated.
I will more than glad to help you in any detail i  might have overloocked.
  • 3 weeks later...
On 16.04.2017 at 5:53 PM, Harni said:
Maalesef hala hiçbir şey yok. Focccus'u kullanırken, IPC'den okumayı denediğimde bunu alıyorum ...
Forscan'ı kullanırsam, yapılandırmayı indirebilir, ihtiyaçları olduğu gibi değiştirebilirim, ancak yedeklemeye yazmaya çalıştığımda bunu alıyorum
herhangi bir fikir erkek çocuklar ve erkekler?
Hi, I have the same problem. Did you solve the problem?
Have you tried to copy the vbf file to that specific path? I've had that error when i tried to use Forscan and it was that simple, just created a folder and copied the file into.
At this point I would have sold the car and bought one with CC already installed. This is however an interesting thread.
It reminds me of a guy I used to know who worked on quality control at Speke during the Ford Escort days. He bought a base model Escort and as it went down the production line all the range topping wiring looms were installed by his mates. Three weeks after delivery  he had a top of the range car, most of the extra parts were of course smuggled out... and he installed them.
Anyway, let's hope it all works out. Don't give up.
23 hours ago, Metalzone said:
Vbf dosyasını bu belirli yoldan kopyalamayı denediniz mi? Forscan'ı kullanmaya çalıştığımda bu hatayı yaşadım ve bu basitti, sadece bir klasör oluşturdum ve içine dosyayı kopyaladım.
thank you for the answer.
I could install other clusters using the Focccus program. I just ran into this cluster error and could not solve it.
in this cluster;
  I have installed F1ET-14C025.BB.vbf.
  I could not load any other vbf.
in this cluster;
I´m sorry not being any help, but, as Focccus didn't read my ECU, i didn't get much experience with it. All my research now is with ForScan.
Anyway, people that Knows this stuff a lot better than me, way better, said that Focccus is not able to read MK3.5's ECU.
Will be soon selling my Tit X steering wheel with cruise control buttons :) so if maybe somebody will be interested PM me.
Anyone have any luck with getting a diesel working?
I hate to bring up an old thread, but here I am doing it again.
I have a 16plate, zetec s focus. 1L 125hp.
What is the success rate for people doing this, as its the only thing I miss having.
I don't have a windows laptop so if anyone in the reading/Berkshire area wants to make some quick dolla and help me out I would really appreciate it.
thank you
Success rate for petrol seems quite high, diesel not so much.
I'm in Kent if you need cruise activated (after replacing your steering wheel with one with buttons).
  • 3 weeks later...
Just to say a big thanks to ChrisCh for helping me get my cruise control working on my Ford Focus 1L petrol.
I had fitted a replacement steering wheel with buttons and my local Ford dealer had said they would do the programming.  They couldn't do it (I guess Ford don't give them the software) and reported the steering wheel was "incompatible" with my car.  Chris enabled the cruise and speed limiter options with his software in well under 5 minutes.
Thanks again Chris.
No problem! Glad to help :smile:
  • 4 weeks later...
Well I’ve given up on this now. Don’t think it’s possivle on a 1.5 until someone is able to access the PCM. Steering wheel is removed so if anyone wants a good condition (minus a small scuff on the right hand buttons silver trim) leather wheel from a mk3.5 with cruise for £50, let me know!
if you can get access to IDS you can do it, might be worth starting a database of members who for some beer tokens would be able to help people out (local of course)
I pick mine up on Thursday so would like to do this, surely it must be possible as Ford do it!  If only it were that easy..
On 06/11/2017 at 3:23 PM, ChrisCh said:
UCDS supply their own adaptors (beware fakes on eBay). You buy the software and hardware as part of a bundle, for either €126 for the basic license, or the extended license for €212. I actually borrowed the laptop, software and OBD hardware this time.
I am currently trying to buy the equipment myself so I can fiddle with some other settings, but it's a slow process!
From my brief look at the software it is a cut above any of the free options out there and allows you to specify which car you are looking at (from the majority of the worldwide Ford range).
Hi Chris,
Sorry to bother, I'm getting a new (2018) Ford Focus 1.0 ST-Line 140 Ecoboost by the end of this month.
Unforunately I couldn't get factory Cruise Control but have read this whole thread and you have made it sound pretty simple!
I live in NW London, do you reckon if I manage to get a steering wheel that you'd be able to activate it for me? More than happy to give you some cash.
Let me know...
Luc
Today i successfully retro fitted cruise control on a 65 plate focus ST TDCI  30 mins for wheel swap and programming :yahoo:
  • 3 months later...
can you tell us how you did it?
Thanks in advance.
Sorry for my English.
Give us more informations. What did you do to make it working? If you managed to do that without anything other than swap + cc activation means that for some reason your PCM was ready accept cc commands.
Really need some help. trying to change steering wheel but have now got hill assist not available and traction control warning light on dash. fitted steering wheel with cruise control controls but had to use forscan because foccus wouldnt work with my focus st. forscan keept show service interupted when writing to secondary bootloader. now got these errors. really need some guidance.
thanks
