Nathan-fiesta Posted October 30, 2017 Share Posted October 30, 2017 Looking to get a set of 18 inch alloys for my fiesta, just wanted to know if they would fit really. Or if they would rub. If it helps the ones i was looking at are the wolfrace assassins : https://www.wheelbasealloys.com/alloy-wheels/wolfrace/assassin/black/18-inch Quote Link to comment Share on other sites More sharing options...
Marcr1 Posted November 5, 2017 Share Posted November 5, 2017 Yeah they will fit but bare in mind you’d probably want to lower the car as well or risk looking like a tractor. Also i assume you’re currently on 16s? The 18s will be significantly heavier so they’ll slow you down a bit 😆 1 Quote Link to comment Share on other sites More sharing options...
jbell Posted November 5, 2017 Share Posted November 5, 2017 You should fit a steering rack limiter 1 Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted November 6, 2017 Share Posted November 6, 2017 Also bear in mind your tyres are going to be so thin you're hardly going to see them. That's only if you pick tyres so that you have the same diameter as standard so you don't have to mess with the speedo. That's asking for curb marks lol. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted November 6, 2017 Share Posted November 6, 2017 Better to keep 16" wheels and lower it on Eibach springs aswell as having the tracking alignment set correctly after lowering, It will handle like a Go Kart without any reduction in acceleration. I've had 18x8 on my focus and after two years I went back to16's because I had a puncture twice and didn't know until the tyre was shot because of the 35mm reinforced sidewall in the tyres, the tyres last maximum 9 months and cost over 100 pounds each, the rims themselves also fracture easily on speed bumps etc. Everything there telling you is true. Quote Link to comment Share on other sites More sharing options...
isetta Posted November 6, 2017 Share Posted November 6, 2017 "That's asking for curb marks lol." and more likely to bend wheel from potholes as not so much rubber to act as a buffer. and you will probably feel the harsher ride. Waste of money in my view but I am old 1 Quote Link to comment Share on other sites More sharing options...
alexp999 Posted November 6, 2017 Share Posted November 6, 2017 Even if they fit, it's a lot of extra unsprung mass for the little 1.25 to move. It's not just looks that manufacturers tie larger wheels to larger engines. 1 Quote Link to comment Share on other sites More sharing options...
