Non Starter
6 replies to this topic
#1 brucie
brucie
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Ford Model: mondeo 1.8lx 2002
Posted 09 March 2010 - 12:41 PM
Mondeo Mk3 1.8lx 2002. She turns over but fails to start. Spark at plugs, fuel cut off switch is depressed, no blown fuses, cannot hear fuel pump priming itself. Is there any other checks I can do before replacing the fuel pump? Most times it would start straight away sometimes after a few turns, now not at all.
Have something to contribute?
#2 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,995 posts
  • Name: arthur
  • Year: 2006
Posted 09 March 2010 - 07:22 PM
sounds like a fuel issue to me might be a new pump time if you have plenty of spark im assuming that the coil pack is fine
#3 stef123
stef123
  • Management
  • 5,864 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 09 March 2010 - 07:43 PM
i would start by checking any fuses and relays specific to the pump and then check all wiring to it and any earths.
also check that there is power getting to the pump.
#4 brucie
brucie
    Newbie
  • New Member
  • Pip
  • 8 posts
Posted 10 March 2010 - 10:37 AM
Ordered 2nd hand one £42 so no great expense if not the pump. Question - can i hook up replacement before installing to see if it runs, thus ensuring its not a wiring fault. Dont want to do any damage. Power is getting to pump, meter reads when ignition turned on.
cheers
#5 L S Auto Repairs
L S Auto Repairs
  • New Member
  • 57 posts
  • Ford Model: fiesta
Posted 11 March 2010 - 01:02 AM
Have you checked to see if your getting fuel up to the fuel rail?
Spark at end of HT leads?
There a 3 amp engine management fuse that blows in the engine compartment check that.
#6 brucie
brucie
    Newbie
  • New Member
  • Pip
  • 8 posts
Posted 11 March 2010 - 09:49 AM
Fuse ok, there is a spark, what is the best way of checking fuel at the rail? If the pump has gone would there still be enough pressure for injectors to inject fuel? Plugs are bone dry.
#7 artscot79
artscot79
  • PipPipPipPipPip
  • 7,995 posts
  • Name: arthur
  • Year: 2006
Posted 11 March 2010 - 06:54 PM
with the pump gone there will be no fuel in the rail as youll have used what was left in the pipe turning it over
Not what you're looking for?
