jamboken77 Posted July 12, 2010 Share Posted July 12, 2010 My air con has been getting less and less cold over the past month, so I thought it would be a simple job of recharging it. I bought a recharge kit from Halfords after reading good reviews and it saves me £30 over going to a garage. I followed the instructions, but it my air con was showing the correct pressure and said it was filled. Any ideas why it might not be as cold if the pressure is showing as correct? Cheers Quote Link to comment Share on other sites More sharing options...
artscot79 Posted July 13, 2010 Share Posted July 13, 2010 My air con has been getting less and less cold over the past month, so I thought it would be a simple job of recharging it. I bought a recharge kit from Halfords after reading good reviews and it saves me £30 over going to a garage. I followed the instructions, but it my air con was showing the correct pressure and said it was filled. Any ideas why it might not be as cold if the pressure is showing as correct? Cheers simply you need to look through the yellow pages and get a mobile aircon specialist to test the system it could be a faulty pressure switch but it could at worst case be a knackered compressor after the issues i had with aircon on my old car and the expense i deliberately chose my focus without aircon hopefully iots just a pessure switch and not too expensive the specialist will test the system and pin point you in the right direction its the cheapest option Quote Link to comment Share on other sites More sharing options...
