Trickling noise from 65+ mph
#1
Posted 19 September 2008 - 07:23 AM
I have a 2001 1.25 Zetec S Fiesta Ghia. When I travel at motorway speeds, I hear a trickling noise from what sounds like the passenger front footwell. I don't have a coolant leak, so the heating matrix is fine as there is no water in the footwell.
Any ideas on what it might be?
#2
Posted 19 September 2008 - 08:13 AM
This is a strange problem and if you have no water gathering then its obviosuly not a leak into the car, are you sure it isnt wind whistling through the window or something like that?
#3
Posted 19 September 2008 - 08:21 AM
The thing with this is that, you can hear with with the heater on or off. I'd alos like to say that the car is running fine & the heater appears to work fine. Though the engine does appear to take a while to warm up (well compared to my Celica).
#4
Posted 19 September 2008 - 08:26 AM
#5
Posted 19 September 2008 - 08:27 AM
#6
Posted 19 September 2008 - 08:28 AM
#7
Posted 19 September 2008 - 12:37 PM
Yeah I do it every weekend.
Have a look in the engine compartment, i had a weird noise from 40mph+ and it turned out to be leaves rolling around because of the draught in a small hidey hole underneath the brake servo unit. I managed to get them out using a knitting needle and since then, quiet as a mouse!
#8
Posted 19 September 2008 - 12:46 PM
If it is an airlock, what would be the easiest way to get rid of it?
#9
Posted 19 September 2008 - 03:00 PM
#10
Posted 19 September 2008 - 03:14 PM
#11
Posted 19 September 2008 - 03:22 PM
I'll keep you all informed!
#12
Posted 16 November 2008 - 08:23 AM
#13
Posted 16 November 2008 - 01:47 PM
I still get this noise. It's not an airlock, so no idea what it is!
Did you check out the 'leaves' noise inside the engine compartment?
#14
Posted 16 November 2008 - 09:07 PM
