nevergiveup Posted October 5, 2011 Share Posted October 5, 2011 I got the reverse direction as well but I wrote the seller and he send a link for the motor with the correct direction. Sad to say however that did not solve my problem. After 6 months of trying everything I was willing to do myself, I eventually went to the dealers and told them fix it. The solution ended up an electrical problem inside the car itself so now the trunk open light doesnt come on at nights anymore when I am driving. hi dicodread, many thanks for prompt reply, my problem "is" the motor.......you wouldn't still have the link for the correct motor? or if you have a correct spare i'll buy it of you ......cheers john Quote Link to comment Share on other sites More sharing options...
nevergiveup Posted October 5, 2011 Share Posted October 5, 2011 hi dicodread, many thanks for prompt reply, my problem "is" the motor.......you wouldn't still have the link for the correct motor? or if you have a correct spare i'll buy it of you ......cheers john i suppose they didn't tell you what the problem was? and they charged like a wounded bull ? i'll probably have to follow the same path dicoread.......ah well that's life......have a nice day to yourself........ Quote Link to comment Share on other sites More sharing options...
dicodread Posted October 5, 2011 Share Posted October 5, 2011 i suppose they didn't tell you what the problem was? and they charged like a wounded bull ? i'll probably have to follow the same path dicoread.......ah well that's life......have a nice day to yourself........ The last Item I bought was "Ford Focus MK2 Boot / Tailgate Lock Motor (220738447168)" from seller "mcamp1on". The original one I bought that didnt work was "2 x 12VDC Mabuchi Motor FC-280PT-20150 High RPM (350403568887)" from "activesurplus" Quote Link to comment Share on other sites More sharing options...
focusberghem Posted November 12, 2011 Share Posted November 12, 2011 Hi folks, I also faced the problem with the moter in the boot. I replaced it with the Mabuchi. For this I removed the contact points in the housing. I drilled a hole in the cover of the housing. Then I soldered two wires on the Mabuchi motor. This wires are brought outside through the hole and connected to the wires near the connector. Wire 1 is used for 12 volt, wire 2 is used for ground (see schematic above in this topic tail lock.jpg). But the real cause of the problem was that the isolation of wires within the rubber hose between the trunk lid and the chassis were all damaged. So all wires could contact each other giving several failures. So I replaced a part of the wires with new wires (first number wires, then cut out the broken part and replace with new wires, then connect wires again). Hopefully this story helps others. Quote Link to comment Share on other sites More sharing options...
dicodread Posted November 13, 2011 Share Posted November 13, 2011 Hi folks, I also faced the problem with the moter in the boot. I replaced it with the Mabuchi. For this I removed the contact points in the housing. I drilled a hole in the cover of the housing. Then I soldered two wires on the Mabuchi motor. This wires are brought outside through the hole and connected to the wires near the connector. Wire 1 is used for 12 volt, wire 2 is used for ground (see schematic above in this topic tail lock.jpg). But the real cause of the problem was that the isolation of wires within the rubber hose between the trunk lid and the chassis were all damaged. So all wires could contact each other giving several failures. So I replaced a part of the wires with new wires (first number wires, then cut out the broken part and replace with new wires, then connect wires again). Hopefully this story helps others. That is a lot of drilling :) Quote Link to comment Share on other sites More sharing options...
gr33ns Posted February 3, 2015 Share Posted February 3, 2015 I had similar problems with my boot, I found that the wire in the rubber boot that go's from the boot lid to the car body was all frayed and shorting out Quote Link to comment Share on other sites More sharing options...
