MattyH85 Posted December 12, 2010 Share Posted December 12, 2010 Hi. Recently on my 2005 new shape focus zetec there has been a knocking noise coming from the rear when turning a sharp corner. I have jacked up but can't see no immediate sign of what it could be. Has anyone got some advice or ideas please. Thanks Matt Quote Link to comment Share on other sites More sharing options...
alz Posted December 12, 2010 Share Posted December 12, 2010 check the wheel nuts, it only needs one to be lose to make the wheel knock when turning. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted December 13, 2010 Share Posted December 13, 2010 check the wheel nuts, it only needs one to be lose to make the wheel knock when turning. have you had any of the front springs replaced? reason i ask if only one front spring was replaced instead of two the rear coil spring will rattle around also check the rear spring has a rubber isolator sleeve on the bottom where it sits in the cup other than that check the rear upper bushes dont move and or are perished Quote Link to comment Share on other sites More sharing options...
MattyH85 Posted December 13, 2010 Author Share Posted December 13, 2010 I will try all of the above. Fingers crossed I can sort it rather then taking it to a garage. Thankyou for your replies. Much appreciated. Matt Quote Link to comment Share on other sites More sharing options...
artscot79 Posted December 13, 2010 Share Posted December 13, 2010 I will try all of the above. Fingers crossed I can sort it rather then taking it to a garage. Thankyou for your replies. Much appreciated. Matt i had it on mine ford checked everything from alignment to bushes springs etc etc and found nothing the only thing was i had only replaced 1 front spring and on the wporn spring side on the front ie the drivers side if turning hard left the weight was transfered to the front the newer spring was pushing up the worn spring was compressing and the rear pass spring rattled slightly for the knock its usually the upper arm look under the side of the car for a large arm bolting up to the car floor this is the bush that wears and causes side movement it takes a lot of force to move it so might not be obvious from pulling at it youll see the bush andf a bolt going through it if the rubber has seperated from the metal they need replaced not a home job so i wouldnt even attempt it if it is Quote Link to comment Share on other sites More sharing options...
coll247 Posted December 14, 2010 Share Posted December 14, 2010 check the exhaust mountings are not worn.it will make it bang if they are check the one on the back box Quote Link to comment Share on other sites More sharing options...
focusian Posted December 15, 2010 Share Posted December 15, 2010 i'm not sure you did mean focus mk2 or not, if so it is better you check from the photos here, http://fordclub.net/module_view.php?mod=webboard&fn=view&cid=63764&sh=%BB%C5%D2%C2%A1%D1%B9%E2%A4%C5%A7 ( it better than i explain by poor eng. :P ) You can see pic. of my reply no. 7/13 , with the red circle. This is one cause of knocking. Quote Link to comment Share on other sites More sharing options...
MattyH85 Posted December 18, 2010 Author Share Posted December 18, 2010 I am not sure whether it has had a new spring fitted. In the few months I have had the car I haven't replaced one. I am going to put it in for a service in the new year so hopefully they will sort it out. Thanks for your replies. Quote Link to comment Share on other sites More sharing options...
