random_d Posted January 8, 2011 Share Posted January 8, 2011 Hi all, new member here. Tried another Fiesta forum and had no help there so trying here in more hope. I've had a problem with the heated rear screen button sticking in when using it. I can pop it back out with a screwdriver but its getting rather annoying doing this all the time. From what I have read this problem is known but my warranty is finished (and i'm not on good terms with the local Ford dealer anyway). Is there a way to remove the front fascia so i can get to the bottons and try and fix the problem myself? I've had the car about 2 years and the problem has only just started. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
DONFRAMAC Posted January 11, 2011 Share Posted January 11, 2011 Hi all, new member here. Tried another Fiesta forum and had no help there so trying here in more hope. I've had a problem with the heated rear screen button sticking in when using it. I can pop it back out with a screwdriver but its getting rather annoying doing this all the time. From what I have read this problem is known but my warranty is finished (and i'm not on good terms with the local Ford dealer anyway). Is there a way to remove the front fascia so i can get to the bottons and try and fix the problem myself? I've had the car about 2 years and the problem has only just started. Thanks in advance. This is a cold-weather problem. I bought my new Fiesta Zetec Climate in Sept. '08, and went back within a month with this problem (just a quick bit of light sanding of the square aperture in the panel:-- 10 minutes.), plus I had notchy gear-changes. I only cured the g'box last summer by filling the 'box with the correct grade of fully synthetic Castrol SMX-S, 75/85 grade, GL3/4, as currently available from Opieoils. The stuff that came out was obviously different, like the Motul Technosynthese semi-synthetic oil. I would take this job to a small workshop, as I did with my front callipers when they needed fettling, at 1 year old. Quote Link to comment Share on other sites More sharing options...
random_d Posted January 11, 2011 Author Share Posted January 11, 2011 thanks for the info. But how do i get into the buttons? do they pop out or do i have to take off the whole fascia and would this mean removing the radio? Quote Link to comment Share on other sites More sharing options...
DONFRAMAC Posted January 11, 2011 Share Posted January 11, 2011 thanks for the info. But how do i get into the buttons? do they pop out or do i have to take off the whole fascia and would this mean removing the radio? Just a part panel to come off. Get the Haynes manual, if you really want to tackle it yourself. There is now a manual for the Mk 6.5. I only got an older manual. Quote Link to comment Share on other sites More sharing options...
