robandnicky Posted November 7, 2008 Share Posted November 7, 2008 On my 04 fiesta, suddenly the CD player will not work and flashes up fault code E24. The CD spins up but then just "trips" back to the radio. Any idea what E24 is and the rectification process?? Any pointers will help. Cheers, Rob Quote Link to comment Share on other sites More sharing options...
mintalkin Posted November 8, 2008 Share Posted November 8, 2008 you could try removing the fuse for a couple of hours to see if the unit will reset, make sure you know your radio code before doing this. Quote Link to comment Share on other sites More sharing options...
Russ Posted November 9, 2008 Share Posted November 9, 2008 you could try removing the fuse for a couple of hours to see if the unit will reset, make sure you know your radio code before doing this. It's something to do with the cd lens losing it's efficiency and disconnecting the fuse or battery wont fix it. Quote Link to comment Share on other sites More sharing options...
MorotMouth Posted November 24, 2008 Share Posted November 24, 2008 normally that means theres an internal problem with the cd player... ford can send it back to get it fixed n itll cost ya.. so will buyin a new ford cd player... best off buyin a new head unit u like itll cost alot less Quote Link to comment Share on other sites More sharing options...
