Smokin
4 replies to this topic
#1 tony b
tony b
    Member
  • PipPip
  • 16 posts
  • Ford Model: mondeo 2.0 tdci 2003
Posted 08 May 2011 - 02:52 PM
hi all
Ive just cleaned the egr and manifold but its still v smokey when accelerating or stood then pulling off.
Acceleration ok but turbo seems to cut in late. Otherwise it starts and idles ok.
The car has been stood for last 5 week or so due to using 2 wheels will the egr or anything else have stuck, or has turbo had it
Thanks for any replies
#2 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 08 May 2011 - 02:56 PM
check for splits in the intercooler pipe, its the large pipe from the bottom of the egr valve.if the pipe is split it will cause black smoke and a lack of power around 1800 rpm.
#3 tony b
tony b
    Member
  • PipPip
  • 16 posts
Posted 09 May 2011 - 08:54 AM
Had pipe off and no splits all vacuum pipes to turbo and egr ok
What do need to look at or do next?
could it be turbo, egr valve, air mass flow sensor/valve!! as a mate has suggested
#4 Huxo
Huxo
    Newbie
  • Pip
  • 7 posts
  • Name: Paul
  • Ford Model: Mondeo TitaniumX 2.0 TDCI
  • Year: 2006
Posted 18 July 2011 - 05:52 PM
Hi Tony
Got the same problem with mine.... did you get this fixed? If so, what did you do?
Paul
#5 tony b
tony b
    Member
  • PipPip
  • 16 posts
Posted 19 July 2011 - 06:41 AM
turned out to be an injector/seal
