Chris Ecc Posted May 30, 2011 Share Posted May 30, 2011 http://www.european-parts.net/catalog/product_info.php?products_id=966 I managed to get one of these for free, I've fitted it into my fez but the Ambient Lights don't work. Has anyone got any images of the back of one that the lights work on? I'm thinking they need wiring up somehow but not too sure! Quote Link to comment Share on other sites More sharing options...
tone Posted May 30, 2011 Share Posted May 30, 2011 Hi Chris I got one and you need to give ut a live feed. I took my feed from a source on the back of the radio which lights up the controls when you switch the car lights on. Because they are LED they don't require a large current. Quote Link to comment Share on other sites More sharing options...
pouly Posted May 31, 2011 Share Posted May 31, 2011 hi chris you are in wrexham arn't you i am in buckley so if you want to call and have a look at mine in my titanium and see if it will help to get yours sorted regards paul Quote Link to comment Share on other sites More sharing options...
Chris Ecc Posted May 31, 2011 Author Share Posted May 31, 2011 I've wired it up as shown here but the lights are always on, even when the car is locked they stay on :S I'm gonna do a test later and see if they go off after a period of time! I didn't realise you lived so close Pouly will have to keep a look out for ya! Quote Link to comment Share on other sites More sharing options...
kevin lancelott Posted May 31, 2011 Share Posted May 31, 2011 Wrexham and Buckley.Small world boys.I in Connah,s Quay. Quote Link to comment Share on other sites More sharing options...
Musketter Posted May 31, 2011 Share Posted May 31, 2011 I can't actually seen the light clearly in the pic, but it seems you have run a switched live (Ignition) to the light. I cannot work out what the black wire is going across the light for ? Firstly remove that wire. If no joy, It is possible that you have got the switched live and the permanent live the wrong way round, or that the switched live is permanently live. Try using a multimeter on the switched wire to see if it is switched (If that makes sense). If it doesn't go on and off with the ignition, then turn the light on with the switch on the light, and see if they go on and off with the ignition. If it does go out with the ignition then you need to swap the two lives wires over. Try that and let me know how you get on ? Quote Link to comment Share on other sites More sharing options...
Musketter Posted June 2, 2011 Share Posted June 2, 2011 I have managed to work it out. The 2 wires on the right are the earth, the one on the left is the live feed. The black wire running across is the problem, and needs replacing with one from a ignition controlled source to the small connector on the right hand side. At the moment it is using a permanent live, hence why it is staying on all the time. Please remember that the lights are controlled by the negative, and not the live feed. Have fun !!! Quote Link to comment Share on other sites More sharing options...
