hocvd83 Posted September 19, 2017 Share Posted September 19, 2017 21 giờ trước, GJC cho biết: Trone you are a machine machines 7,5 (is the Mk 7 facelift). I can not find the any markers around the motor, you will be seen 4 x 2cm colors if they mounted, hai at the bottomward, and two mount. Cáp can not connected as hard disk is not at that. Thank you so much. Quote Link to comment Share on other sites More sharing options...
hocvd83 Posted September 21, 2017 Share Posted September 21, 2017 Hi, you know this function (switch headlight), thank you. and you can send link guide? Quote Link to comment Share on other sites More sharing options...
yunii Posted September 21, 2017 Share Posted September 21, 2017 Hi, you know this function (switch headlight), thank you. and you can send link guide? Hi , looking at that switch your headlight beam should be set at 0 setting as number settings are when you towing which with weight at rear will raise the front so beam aim needs to drop.YuniiSent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
GJC Posted September 21, 2017 Share Posted September 21, 2017 5 hours ago, hocvd83 said: Hi, you know this function (switch headlight), thank you. and you can send link guide? Hi Your national Vietnam Ford web site may have a area where you can enter the make model and VIN to get a user manual for your car. I know the Uk and US ones have them so I assume it's all country level Ford sites Quote Link to comment Share on other sites More sharing options...
yunii Posted September 21, 2017 Share Posted September 21, 2017 So in that case is this the plug for esp switch ?I currently bought piano black mk7.5 trim & it came this switch.All it does is illumenate led. It does not have esp written on it.YuniiSent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
hocvd83 Posted September 22, 2017 Share Posted September 22, 2017 20 hours ago, yunii said: Hi, nhìn vào đó chuyển đổi chùm đèn pha của bạn nên được đặt ở chế độ 0 như cài đặt số là khi bạn kéo có trọng lượng ở phía sau sẽ nâng cao phía trước để mục tiêu chùm tia cần phải giảm. Yunii Gửi từ SM-G925F bằng Tapatalk Thank you. Quote Link to comment Share on other sites More sharing options...
hocvd83 Posted September 22, 2017 Share Posted September 22, 2017 15 hours ago, GJC said: Chào Trang web Vietnam Ford quốc gia của bạn có thể có một khu vực mà bạn có thể vào mô hình làm và VIN để có được một hướng dẫn sử dụng cho xe của bạn. Tôi biết những người Uk và Mỹ có họ vì vậy tôi cho rằng đó là tất cả các trang Ford cấp quốc gia Hic, Vietnam ford not support, i can't find :( Quote Link to comment Share on other sites More sharing options...
yunii Posted September 23, 2017 Share Posted September 23, 2017 No INath you have pm mate.YuniiSent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
hocvd83 Posted September 27, 2017 Share Posted September 27, 2017 Help. Do you have diagram nosit (Body Control module)? i need it (ford fiesta mk7.5) Thank you. Quote Link to comment Share on other sites More sharing options...
