Brian balmer Posted January 4, 2012 Share Posted January 4, 2012 I have a 58 reg focus tdci 1.9 which is making a deep noise from the air box, someone said check the turbo pipes , done this but all ok, suspected a blocked cat , removed cat and noise still there, any ideas people? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 5, 2012 Share Posted January 5, 2012 I have a 58 reg focus tdci 1.9 which is making a deep noise from the air box, someone said check the turbo pipes , done this but all ok, suspected a blocked cat , removed cat and noise still there, any ideas people? Not being silly but have you checked the air filter is installed correctly? Possibly a damaged or missing seal? Quote Link to comment Share on other sites More sharing options...
Brian balmer Posted January 5, 2012 Author Share Posted January 5, 2012 Thanks for ur reply , bt I have checked ul that already, noise is there wen airbox is off. My friend said check the EGR valve, possibly jammed open so am js about to try that, il post wot I find, cheers Quote Link to comment Share on other sites More sharing options...
alanfocustdci Posted January 6, 2012 Share Posted January 6, 2012 If your car is fitted with a DPF it could be that that is blocked. Are there any dash lights on? My brothers 530D started making a deep whistle after his particulate filter was blocked.. also have you checked the integrity of your exhaust system? Quote Link to comment Share on other sites More sharing options...
Brian balmer Posted January 8, 2012 Author Share Posted January 8, 2012 Alright Alan , cheers for your reply, I have checked the exhaust system in full, all ok. Have no dash lights ok either but will check the dpf. Noise is more prominent wen air feed pipe is removed from inlet manifold , friend said the block bores may be oval'd and causing back pressure , which the car has slightly, but don't have compression tester to find out, have u came across this before? Quote Link to comment Share on other sites More sharing options...
