antihero711 Posted February 22, 2012 Share Posted February 22, 2012 Hi everyone. Im looking to do something different with my fiesta. Its the 2003 mk 6 finesse model. I know that its not quick and would cost a bomb to make it quick without an engine conversion. Does anyone know what engine would go in with the least amount of work possible and not too much money spent. The something different that i want to do to it will come in after an engine most probably. Soooo any ideas??? Quote Link to comment Share on other sites More sharing options...
james_60 Posted February 22, 2012 Share Posted February 22, 2012 hi anti You can do these things if you have money 1. Get it remapped (5bhp at least) 2. Panel Filter (1-2bhp) Cone Filter (same) 3. Sports Exhaust (4-5 bhp) 4. Sports Catalyst (4-5BHP) Bearing in mind the std BHP is 75 net and that is before it goes through the transmission (at least 25-30 BHP per wheel) some power is lost in the gearbox Bearing in mind that the engine is standard remember that increasing the power of the car is of course very costly so is the insurance you need to enable you to drive the car. Insurance may go up substantially because all of the above are classed as modifications. Also Increasing the Engine power means it requires more stopping power Renew Brake Pads with fast road versions. Consider replacing the disks for performance ones. Change the brake fluid The Clutch will also have to handle more power and if this is already well worn it will finish it off. Sorry if this puts you off. its easy to plan these upgrades but paying through the nose for them is the hard part with both insurance and the actual parts etc p.s add me as a friend and i will help as much as poss Jamie :-) Quote Link to comment Share on other sites More sharing options...
antihero711 Posted February 24, 2012 Author Share Posted February 24, 2012 Hi. Thanks Jamie. But what i really wanmt to do is find out the best/easiest new engine to fit. Any ideas? Quote Link to comment Share on other sites More sharing options...
dLockers Posted February 24, 2012 Share Posted February 24, 2012 If it doesn't have ABS then you have only the 1.6 (100bhp) as an option. If it has ABS then you can swap the ST engine in. It's very unlikely it has ABS. I recently swapped my finessee 1.4 tdci to a 1.6 tdci, its a fun project but I required a whole donor car to do it so I could add ABS/Canbus. Quote Link to comment Share on other sites More sharing options...
antihero711 Posted February 24, 2012 Author Share Posted February 24, 2012 Awesome man thanks. At the risk of sounding like an absolute idiot whats the easiest way to find out (without slamming the brakes on) if i have abs or not? Quote Link to comment Share on other sites More sharing options...
antihero711 Posted February 24, 2012 Author Share Posted February 24, 2012 Found out that i dont have abs. Whats the 1.6 engine like? Quote Link to comment Share on other sites More sharing options...
dLockers Posted February 24, 2012 Share Posted February 24, 2012 100hp, not worth it unless you do all the work yourself. Engine is cheap off of eBay (£400~) Quote Link to comment Share on other sites More sharing options...
