StanH Posted November 17, 2012 Share Posted November 17, 2012 I wanted to use my fog lamps for the first time yesterday but cannot. I have this type of switch and it appears that I should be able to depress it twice to be able to switch on but I cannot I can depress once and pull two or three times but I can't find any position that will let me turn the switch to either of the lowest positions. Any ideas please? Quote Link to comment Share on other sites More sharing options...
Fastfordman Posted November 17, 2012 Share Posted November 17, 2012 I think you actually pull it out not push in, half way out is front fogs and all the way out is rear fogs as well. That's how my old mk2.5 was. It doesn't actually turn to the position shown, it just goes on how far out the switches pulled. Quote Link to comment Share on other sites More sharing options...
StanH Posted November 17, 2012 Author Share Posted November 17, 2012 That did it, thanks In sidelight position, one pull puts on front fogs, second pull indicates that rear is on - mine is not on but must suspect bulb. Wish the manual was more helpful Quote Link to comment Share on other sites More sharing options...
StanH Posted November 17, 2012 Author Share Posted November 17, 2012 Next problem - there was no bulb so thought I was home and dry but single centre and side contact bulb same as reversing does not work, and the interior of the holder seems unduly complicated so I have no idea of the physical characteristics of the bulb I need. Once again, any help appreciated Quote Link to comment Share on other sites More sharing options...
Fastfordman Posted November 17, 2012 Share Posted November 17, 2012 Looking on the Halfords website it definitely shows the rear fog and reversing light are the same, try putting the reversing light in to see if it works. The fact the bulb is missing may suggest there is a fault and someone took out to stop it blowing etc Quote Link to comment Share on other sites More sharing options...
StanH Posted November 17, 2012 Author Share Posted November 17, 2012 Yes, I tried several similar bulbs with no success so you are probably right about a snag somewhere. I just don't see what is going on in the holder - never seen anything like it so it's a problem to find how and where to check for voltage Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 17, 2012 Share Posted November 17, 2012 Check the fuse. The rear fog light has its own circuit. The fuse position should be listed in a link at the end of my signature. Quote Link to comment Share on other sites More sharing options...
StanH Posted November 17, 2012 Author Share Posted November 17, 2012 I must be blind - I can find 69 which is for all the fogs but nothing for the rear alone Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 17, 2012 Share Posted November 17, 2012 I may be mistaken then. I'm on my mobile so can't verify TBH. It may be worth checking the bulb holder for corrosion or a damaged wire. Quote Link to comment Share on other sites More sharing options...
StanH Posted November 17, 2012 Author Share Posted November 17, 2012 I will try to take a pic of the holder tomorrow - it is quite unusual to me. Quote Link to comment Share on other sites More sharing options...
StanH Posted November 18, 2012 Author Share Posted November 18, 2012 Some pics of the rear fog bulb holder - I don't know what sort of bulb it needs, or how to test Quote Link to comment Share on other sites More sharing options...
STEADS Posted November 18, 2012 Share Posted November 18, 2012 theres your problem stan you need a new holder as that one is corroded to hell will never work and will be the cause of blown fuse if that has gone as well i will have a look in my array of spares as i,ve changed lights on other focus so possible got a spare holder you can have will get back to you if i can find one even throw a bulb in Quote Link to comment Share on other sites More sharing options...
STEADS Posted November 18, 2012 Share Posted November 18, 2012 stan looks like your in luck post a picture of the back of it looking at the front i have the part you need Quote Link to comment Share on other sites More sharing options...
StanH Posted November 18, 2012 Author Share Posted November 18, 2012 Hi Steads, will this do? I have scraped all the contacts but it looks to me as if I need a two contact single filament bulb - if such a one exists Quote Link to comment Share on other sites More sharing options...
StanH Posted November 18, 2012 Author Share Posted November 18, 2012 Is this possibly what I need? http://tinyurl.com/avnlghn Quote Link to comment Share on other sites More sharing options...
STEADS Posted November 18, 2012 Share Posted November 18, 2012 Stan i,ve got the piece you need pm your address and i,ll pop it in the post Quote Link to comment Share on other sites More sharing options...
STEADS Posted November 18, 2012 Share Posted November 18, 2012 thats the correct bulb if it still dont work your welcome to this bulb holder i have here Quote Link to comment Share on other sites More sharing options...
StanH Posted November 18, 2012 Author Share Posted November 18, 2012 Thanks - see PMs Quote Link to comment Share on other sites More sharing options...
