hello all
i have a problem with my 06 reg 2.0 130 mondeo
it starts with no problem but it goes all to pot ie stuttering and trying to cut out sometimes it will let you rev it with no problems apart from a slight lumpy bit to it you can drive it and it has no problem getting up to speed
when it idles its verry rough and cuts out
this is what i have done so far
took off egr valve cleaned it not much in there
took off inlet manifold cleaned it not much in there
new air filter
cleaned maf
fault codes i have found
stored
p0100 power train maf sensor ckt insufficent activity
p0251 powertrain injection pump fuel metering control "a" malfunction cam rotor injector
pending codes
p0409 no defernidyion
p0404 powertrain exhaust gas recirculation egr open position performance
what else can i try
any advice is very appreciated
thanks
john
Mondeo Rough Idle Runs But Cuts Out
Started by john34, Dec 03 2012 07:21 PM
7 replies to this topic
#1
Posted 03 December 2012 - 07:21 PM
#2
Posted 04 December 2012 - 03:07 PM
fuel filter??
#3
Posted 04 December 2012 - 04:28 PM
Hi thanks for reply
Not done fuel filter yet as if it is the fuel pump and I put new fuel filter on
I have been told I will get silver peces of metal in it and
That fuel filter will be no good but if the engine runs ok if I rev it I cant see it being the pump
#4
Posted 04 December 2012 - 06:51 PM
when you cleaned the egr did you get a vacume on the valve to see if it operated ok, it could also be the injectors playing up,either by losing their code to the ecu or one injector not firing right, these can be checked by a leak of test.
#5
Posted 04 December 2012 - 07:37 PM
Check camshaft position sensor too, if it's dying it doesn't speak to the ECU properly and the timing can be advanced or retarded when it doesn't need to be, causing lumpy running.
#6
Posted 06 December 2012 - 05:28 AM
Thanks for the replys
Egr I used the pipe and gave it a sucking lol and it opened
Camshaft sensor how do I test it and where do I find it I think it's on the gearbox side
I shall try and check the timing if I get chance
Thanks again
John
Thanks again
John
#7
Posted 06 December 2012 - 07:14 PM
hi all
just to update
i have brought f super and using formidable i get these dtc codes
p0409 exhaust gas recirculation sensor a circuit
p0404 exhaust gas recirculation control circuit range performance
p0622 generator field terminal circuit
any heads up on these codes
i dont have enoght time as yet to play with the car i will keep you updated
thanks john
just to update
thanks john
#8
Posted 06 December 2012 - 08:39 PM
hi
even tho its raining i have done the following
replaced fuel filter with a ford bosh one
spray carb cleaner down air pipe
found a nut missing off a glow plug
again she will rev and hold rev but wont idle
cleared dtc codes
forgot to say the batt light is allways on
same as before now i get
p1632 smart alternator fault sensor circuit
p0404
p0622
any help and where to look would be great i will get a nut on the glow plug
i brought this car as having a problem but i think it has had a new clutch as its very sharp so may be a wire loose or a plug not in right this is a much as i know about the car
thanks a lot
john
cleared dtc codes
p0404
p0622
thanks a lot
john
