Driver Side Front And Back Water Leak?!
#1
Posted 29 December 2012 - 06:55 PM
what i recently notice was my rear foot well was soaking wet with water there is some at the front as well but there was alot must of been like a bottle of water or more i thought it was someone spilled water on it but i cleaned and dried it out and it came back again must be rain water im thinking? i have no idea what it could be. i got it booked it at ford in two weeks time to check but they will charge me to have alook at it and fix so i want to know if anyone know how to fix it etc so i can save abit of money? i have already tried and look at the A Pillars but no sign of water leak there really? unless i done it wrong. i also notice my car get mist up really easy? could that be a reason as well
thank you
tommy
#2
Posted 02 January 2013 - 12:51 PM
#3
Posted 02 January 2013 - 09:14 PM
thanks for the reply sorry for the bad news your having as well! strange thing my boot is completely dry i just have no idea where the water is coming in to the car!I had a water leak on back seat and boot - about 3 inches of water in the wheel well. It first happened when it was 4 months old and they supposedly fixed it. Headlining had to be replaced as marks came through. All fixed under warranty. 2 leaks in roof (roof rack trim) and 2 in body work. That was a year ago now its happened again.
. Screen mists too!
#4
Posted 02 January 2013 - 10:45 PM
I replied to a member this morning with the same problem I paid £288 first time
I ad to go back it was still leaking I gave the fords customer relation a call and they was
Very helpful and I got it fixed for nothing, if you follow the water leak links there's
Some good information in there.
#5
Posted 12 January 2013 - 10:40 PM
hello there do you know what was done to your car? because i might just do it myself i heard i need to put some seal on my a pillar ? thank youHi tommy
#6
Posted 12 January 2013 - 10:44 PM
#7
Posted 12 January 2013 - 10:47 PM
thank you for the advise i have already checked them and they all them good to me to be honest. dont really want to take it to ford since they going charge me even though the cars less then 2 years old ( stupid water leak not covered )the onlt way water can come in through your window, or door seals...... mayb window screen going back of your dashboard unsure.... just check you have a tight seem/window when eveything is closed... try hitting it with a jet wash to see if you can spot the leakage....
#8
Posted 12 January 2013 - 10:53 PM
#9
Posted 12 January 2013 - 11:11 PM
it comes with warranty but water leak is only covered for the first 12months.. stupid it is!tbf why should you have to pay extra..... doesnt the car come with a statuary warranty anyway?? what is water leak cover? (i bet only ford does this, like a anti rust cover lmfao) its a defect, doesnt work/prevent leakage like it should do.....
#10
Posted 12 January 2013 - 11:14 PM
#11
Posted 12 January 2013 - 11:18 PM
#12
Posted 12 January 2013 - 11:37 PM
#13
Posted 14 January 2013 - 01:03 PM
sorry i can't help you with what seal it was but mine ad gone in two places, one at the top of the wing
just below the bonnet hinge you can see the seal where they have put some touch up paint on it, the other one was where the wing fits on to the bodywork the guy was pointing to the door pillar between
drivers door hinges, the water was running in between the trim and sill and coming in at the back of drivers seat up through the underlay and carpet in the passenger footwell,so far so good, they did say bring it back if it happens again, i'm sorry if it's not much use and hope you get it sorted soon there must be thousands out there with this problem fords should know it must be a major problem.
#14
Posted 14 January 2013 - 11:04 PM
hello mate is it possible you can post pictures of repair? that would be helpful thank you!hi tommy
