Gearbox Oil
#1
Posted 28 January 2013 - 06:22 PM
#2
Posted 28 January 2013 - 06:45 PM
Have you any idea at a guess how much oil you lost?
#3
Posted 28 January 2013 - 06:49 PM
#4
Posted 28 January 2013 - 06:53 PM
Thanks for the reponse, I wouldn't say a lot but maybe half a coke can, maybe less? Hard to say really, I did have a tray underneath to catch any I loose but British weather decided to take it for a trip in the wind! We've just noticed that the brake and clutch fluid is quite low so we're going to go get some in a bit, any dot4 will do I guess?
so maybe 150ml give or take? i wouldnt have thought that amount would make a great deal of difference unless the level has been low already.
with brake fluid, i never top mine up even when the level appears to have dropped - when the brakes wear the fluid level will drop and when the pads are replaced and the pistons pushed back the fluid can over flow. you should always be above the minimum though
but yes dot 4.
#5
Posted 28 January 2013 - 06:58 PM
#6
Posted 28 January 2013 - 07:14 PM
#7
Posted 28 January 2013 - 07:43 PM
