polyal
Wont Start Endura 1.8De
hi
its getting diesel ..its got new glowplugs..it didn't breakdown
but now it wont start..it just tries to fire but just puffs out grey smoke even with plenty of cranking power
can anyone help
its a 1999 V REG fiesta 35 van
regards
polyal
I would double check the Glo Plugs and wiring to them , put the old ones back in see if it starts
hi paul
thanks for the reply..the glow plugs are definately working..they have a resistance of about 3ohms
are sinking about 15A each when the glowplug indicator is on + they were bench tested before they were put
into the vehicle ( 3 of the original glopugs were faulty..hence the new set )
someones mentioned giving it a tow start ..does this make sense
its cranking really well on a fully charged battery
regards
polyal
I would still say there may be a problem with the glo plugs to be getting grey smoke , a compression test might shed a little light on the subjuect as well.
Switch them around in case the first one is faulty
hi paul
regards
polyal
If they are drawing about 15A each then the resistance will be more like 0.8 ohms
in effect the resistance is short circuit + the device ( gloplug ) when it gets hot the resistance increases
the 3 ohm reading is the multimeter readout which is very dependant on the multimeter spec
so 3 ohms is as good as a short cicuit ( but not quite ) hence the effect of the gloplug
if you short circuit a battery with a zero resistance material then nothing happens
because there is no voltage drop ...so no current can flow
the nearest you can get to zero resistance is silver ...but never zero
I would love to see someone short out a battery with something of '0' resistance, the battery's internal resistance will cause it to heat up and probably explode
Just hope I'm not around someone trying it :lol:
