wiwi35
Esp And Abs Indicator Lights
Hello to all
equipment for information: I have a ford kuga 4x2 2.0TDCi 2008
here is my problem:
after checking by mistake elmconfig in BCM configuration
box kuga 0:4 x2 drive, and DDS
error message on the dashboard and appearance ESP and ABS warning light on permanently
No backup made
I have a suavegarde another kuga a friend the same but the rewriting does not work.
0 kuga box is not checked in reading.
3 error messages in DTC: C276, E0 --- C2769, U0102 --- E0, E0
What do you think?
sorry but my english is not perfect
post-43208-0-93041800-1367506594_thumb.p
post-43208-0-94237500-1367506599_thumb.p
post-43208-0-80248900-1367506604_thumb.p
post-43208-0-15427700-1367506609_thumb.p
Go here
Enter your VIN number , see if will let you get your AS_BUILT then load the AS_BUILT and save to your car to restore the car defaults
save the AS_BUILT data to Notepad and keep safe if you can get it.
http://www.motorcraftservice.com/vdirs/SPubs/default.asp?pageid=spubs_as_call&nomenu=yes
If this work's please remember to do Page backups when using ELMconfig.
Sorry just looking at this i can't see in ELMconfig where to load AS_BUILT so this idea may not work.
You could always have a look at this program see if you can use this to load the as_built.
FDS.zip
software installation and after reading it gives these impressions screens below.
Sorry I hid some data because I do not know if this is exploitable by dishonest persons outside the site. I think you understand me.
What to do now to read this??
I did not backup??
can you give me the procedure to save before eventual change that seems fair.
thank you for your interest in my mechanical problem
post-43208-0-58991900-1367564522_thumb.p
post-43208-0-62183400-1367564532_thumb.p
post-43208-0-45902200-1367564551_thumb.p
post-43208-0-51592300-1367564565_thumb.p
I managed to have my as built VIN request with my motorcraftservice.com.
I save in text format
What should I do now?
I put my original built, I found that everything is delivered as the original except that both lights are still there. On the software elmconfig DDS is always checked and ford, he is not??? weird
still same error elmconfig and impossible to erase.
Ok
With FDS try and un-tick DDS then save to car , disconnect and the re-connect see if that clears it , you could also try the Restart module function to see if that clears the fault.
You could also try the English version of ELM-FF2 on the first page of my guide see if that helps.
impossible to click on load or save left, is this normal?
post-43208-0-21284300-1367588735_thumb.p
DDS isn t check on FDS but only on elmconfig
Then try and check it and save , then dissconnect then go back and see if you can then un-check it , it might just be a glitch where is stuck , three programs you could try all three to remove click/un-click maybe one might remove the error.
ok I'll try to recheck and record and see if it unlocks the module on elmconfig
on FDS i don't know
no communication with IPC module is faulty. Even a colleague with a suitcase can not correct that the kuga is 4 * 4 * 4 instead of 2.
I was looking for a solution contnue
with FF2 and elmconfig I do not manage to reset the IPC module
do you know the solfware FOCOM Apparently it would be the most appropriate????
I have never used that software no.
Try Loading FDS , and click to get your As_built see if that works , or try and load your as_built before you connect to the car then if it loads try and send to the car that way.
Another thing that may be worth a try is with your mates Kuga
Download and save his as_built file from his Kuga , edit it to exactly what yours should be and try and upload it to your car,
Just a thought did you also under HEC un-tick AWD Kuga
HEC in the AWD box is not check. Should I check knowing that I have a 2x4 and not 4x4?
Putting the as built of my friends wrong t it injects its VIN???
I try this solution this afternoon.
No software happens to erase errors. So this week stint at Ford because the module does not respond, so he stays on despite the different software used
I am has the search a person possessing the IDS software to have access to HEC so possible coach not possible with FDS of loader
Direction(Management) 02 garages ford yesterday then suitcase with the software IDS but the impossible to integrate(join) and to collect the information of origin!!! Strange but I think that they did not know well enough the possibilities of the software. They were very cool when même. - I try to find a person knowing perfectly the software and using him(it) regularly.
